I have been working on my 1980 Camaro/LQ4 restomod for the past several years and I finally fired it this weekend and it is running really rough. First fire I was getting P0200 code which ended up being a damaged injector pigtail (injector 6) so I repaired that but I am still having a problem with bank 2. I checked remainder of wiring and it appeared good and noid light shows all injectors pulsing. I have attached my tune and two quick logs that I took. At this point I am guessing it is either clogged injectors or bad o2 (but they are brand new ac delco), but I was hoping someone more knowledgeable with Gen III tunes/logs might be able to spot something that I am missing. I really want to take this for a drive since the car hasn't moved under power for around 10 years. Any help is greatly appreciated!
Equipment/Mods:
Stock LQ4 - 2003 Express 3500 donor
Speartech reworked harness
85mm truck maf
long tube headers
segment swap auto to manual
