I will take one tonight and post it.
Sent from my iPhone using Tapatalk
I attached the log showing the surging at constant rpm. I checked the tps and map via the scan tool and they both seem to be fine. I have checked for additional vacuum leaks and have not found any. I noticed tonight that it only seems to occur above about 1000 rpm and the surge seems to get more pronounced with increased throttle/rpm. If I give it a quick rev it will be fine but if I give it successive revs it will cut out and almost die after the first rev.
Interesting... looks like some air/fueling/spark loop... can you post your tune file.
Joecar do you think it's possible the pcm is bad? Tonight I did a full flash of a 4.8 manual tune (could not find a 6.0 manual tune) and copied in the engine tables and it still did the same. Everything is fine until about 1300 rpm then it starts stumbling like in the video.
When you did the segment swap, did you do a full flash...?
Yes I did do a full flash with the segment swap. I only have the the PCM but could look on eBay for another one. I have a spare 512k pcm but not a 1k.
I full flashed the original auto tune in and disabled all of the auto stuff and it seemed to fix the problem. It will rev fine now. I am going to compare settings/tables between the two and see if I can spot the offending settings. Unless the segment swap some how corrupted the tune?
