Results 1 to 10 of 10
Thread: C7 with two codes cant be disabled in tune file
    Lifetime Member wesam's Avatar
    May 2010
    Default C7 with two codes cant be disabled in tune file
    I have a problem with two Corvette C7 with after market Catback systems the cars showing two codes : P12E7 and P12EB
    but when i search for the codes in the tune file for the cars i could not find it to disable it
    Any help will be appreciated
    Thanks in advance
    EFILive Tuner
    Aug 2010
    If you disconnect the OEM exhaust flow control valve, you will likely set those codes (and often more). I believe those DTCs are from the BCM (GM may be calling it a CCM in the new Corvette).
    May 2010
    So what people do when installing aftermarket exhust system im C7 ?
    Is there any way to disable these codes ?
    EFILive Tuner
    I suspect you might have to put some sort of resistive circuit where the solenoid used to be so the controller (I thought it was the FSCM) doesn't report the code.
    Aug 2010
    Quote Originally Posted by wesam View Post
    As an example, if you look at Borla’s website, you will see that they offer 2 cat-back kits for the C7. For all C7’s, the AFM exhaust flow valves (before the mufflers) are retained in the Borla AFM kit. For C7’s with the NPP exhaust (Z51 option) there are also exhaust flow valves after the mufflers.
    Any cat-back kit without these flow valves (or that do not retain the OEM flow valves) will cause DTC issues.
    Regarding what to do with a cat-back kit that does not incorporate the exhaust flow valves ... don’t use it, unless you are willing to have the MIL on forever. I believe some people who installed kits that did not incorporate the exhaust flow valves – ended up removing these from the OEM exhaust system, plugging in the electrical connectors, and then mounting them out of the way.
    May 2010
    It seems that the other software can flash the Chassis Control Module now
    I hope this will be added in the future in EFILive
    Thanks in advance
    EFILive Tuner
    Apr 2010
    Thanks in advance
    Have you seen this in person or just going on "rumour" around the place. Screen shots would be great.
    Jul 2003
    There is an emulator for the valves....
    Contact me.. i might be able to help you
    May 2010
    Screen shots in the first post you can check it
    EFILive Tuner
    Apr 2010
    yeah of the "tuning software" on offer from other brands...not your fault codes!! I included your post with what the query was in reference to....
  1. Truck won't run when MAF is disabled for SD tune
    By kbracing96 in forum Gen III V8 Specific
    Last Post: May 2nd, 2013, 04:43 AM
  2. EGR codes after new tune??
    By husker_diesel in forum Duramax LB7
    Last Post: March 30th, 2009, 07:37 AM
  3. Wouldn't it be easier to tune with PE mode deleted/disabled?
    By Supercharged111 in forum Vortec V6/V8 Specific
    Last Post: March 15th, 2009, 12:16 PM
  4. SD tune with MAF codes
    By Z06PSI in forum Gen III V8 Specific
    Last Post: November 10th, 2008, 01:57 AM
