Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Bag of parts........
    Apr 2014
    Default Bag of parts........
    WELL GOT TO PICK A FEW OF YALLS BRAINS ON THIS ONE. Did a injector job on a lb7 with 30% injectors. truck ran great cool egts. two weeks of past customer now has us add the bag of parts to cp3 now running warm egts and smokey now. I got data logs of it. would it be the fuel pressure or injector pulse needing the change.
    Dec 2013
    What parameters are you logging? Can you post it up?
    Apr 2014
    I am doing rail and and injector pulse is what I am looking at.i do have the data log figuring out how to post it in here
    Dec 2013
    Quote Originally Posted by Scarface View Post
    I haven't done anything in depth with an LB7 but does it offer FCA PIDs like duty% or amp?
    Are you logging RP actual and RP desired as well?
    TP, RPM, Coolant, Boost, Main timing, Pilot timing, Main qty, Pilot Qty, Main pulse, RP_A, RP_D, FCA% or amps. Need to see the whole picture to determine the cause of EGTs and smoke.
    It could be the Bag of Parts agitating a timing vs qty issue (not saying there is infact an issue with the tune, but I've seen it). But if FCA is really low or erratic and RP is possibly overshooting the target. It would be an obvious CP3 issue.
    There are many variables once hardparts get changed as we all know.
    Apr 2014
    true on that. I know she is pissy about it
    Mar 2009
    1st things first, how was desired vs actual rail before? Next how is it now? I don't remember the PID's right now, but there is one to watch for total fuel system flow(it is a hypothetical PID as it is impossible to measure total flow. Also log actual VS desired rail valve current. With the extra fuel, you're probably overshooting your rail pressure some, and it's slow to bring the pressure back down causing over fueling now.
    Apr 2014
    ok thefermanator. I watched the data log this morning and I can see the two pressures are running the same but I do notice a dip in the graph then comes back. I suspect like u said I am over shooting the fuel pressure in it. I do have the data logs if u wanna take a look. I do have the tune. just figuring up how to post them in hear
    Dec 2013
    I haven't posted logs before but can't you just go to advanced reply and attach files there?
    Dec 2013
    2001 Chevrolet Silverado Truck Automatic LB7 6.6 Litre.tun
    This is just an attachment test LB7 stock file.
    Dec 2013
    Sorry to keep spamming your thread.. What injectors are they and did they come with flow chart/stats for adjusting pulse width vs. volume?
  1. Can I keep the same tuning if I downgrade parts???
    By kansasfarmboy32 in forum Duramax LLY
    Last Post: August 24th, 2014, 02:44 AM
  2. Random battery, abs, air bag and brake light.
    By Slowrc in forum Gen III V8 Specific
    Last Post: March 10th, 2014, 01:46 AM
  3. my air bag light came on after a tune
    By ace68 in forum Gen III V8 Specific
    Last Post: May 15th, 2011, 10:44 AM
  4. GM Performance Parts Catalog
    By vzsv8 in forum Lounge
    Last Post: February 25th, 2009, 10:08 PM
  5. Can I scan for an air bag code??
    By 06bowtie_guy in forum General
    Last Post: March 12th, 2007, 02:19 PM
