Results 1 to 7 of 7
Thread: new to EFi Live here
    Jun 2016
    Default new to EFi Live here
    Got my Efi Live here. it tells me my cmd files can't be found gave me a $0502 and a $FFFF
    any help would be great to get my truck running again. just got it back from the shop they put on, exhaust, intake,egr/egr cooler delete.
    would like to start my truck without hurting anything. they towed it back to my house.
    also when I got to read program flash, program full it says wrong ecm type
    May 2008
    what year?
    2015 3500HD crew cab long bed, 6" fabtech, slightly tuned, emissions intact.
    2005 dmax ccsb, EFI live tuned DSP 5 Full built motor, S471 billet single, More better built trans this time. and lots of other things.
    1984 CJ7 powered by a 2000 LS1. 4L60E.
    2012 Jetta TDI 6 speed manual, (yes the dirty the bastard haha)
    2003 Jetta TDI,
    1986 K10 LQ4/4L80E
    Jun 2016
    2012 2500 6.7L laramie
    i know I have the cmd cm2200a but it will throw all the codes from the deletes i'm sure if i just start the truck.
    Do I have to take the ecm off the truck for anything to connect to that?
    May 2008
    Are your trying to download the tune? if so you can't do that you will need delete tunes from a tuner like PPEI or Hardway and use the boot patch tune to unlock then flash in the tune from them.
    2003 Jetta TDI,
    1986 K10 LQ4/4L80E
    Jun 2016
    i'm just trying to get the tune from the Efi live flashscan v2
    it has the
    stock tune
    smokeless
    economoy
    power
    towing
    on the tuner already i would kike to just get the economoy and towing on my truck. That way i can at least drive it to work .
    i have everything setup so i can read how the truck is running but when i try to put the tune on the truck i keep getting that $FFFF tune switching ,
    and i get the $0502 in the tuning and program full it has the cmb_0001 and cmb_0003 and it then gives me that 502 code
    May 2008
    your V2 isn't configured to flash that controller. are you trying to black box flash it with just the V2 or are you trying to flash it with a laptop? sounds like you are trying to flash it with just the V2 alone with tunes on an SD card inserted into the V2?
    2003 Jetta TDI,
    1986 K10 LQ4/4L80E
    Nov 2005
    FlashScan requires configuration prior to use. Here is the setup document. https://support.efilive.com/kb_artic...6659-YAHB-3781
    Cheers
    Cindy
    Sent from my iPad using Tapatalk
  1. new to efi live
    By nam516 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 11th, 2012, 10:54 AM
  2. Replies: 10
    Last Post: December 26th, 2011, 08:44 PM
  3. Efi live class at efi university
    By Robbie The Wrench in forum General (Petrol, Gas, Ethanol)
    Last Post: September 1st, 2008, 02:25 PM
  4. New to EFI Live
    By Whitetail Addict in forum Lounge
    Last Post: August 25th, 2008, 06:15 AM
  5. Efi live on the way
    By 04llygmc in forum Duramax LLY
    Last Post: March 5th, 2006, 06:21 AM
