Results 1 to 10 of 11
Thread: 2011 "reduced power message" no codes
    Aug 2014
    Default 2011 "reduced power message" no codes
    I have a 2011 I am trying to tune as a favour and I am at a roadblock. Originally my friend paid a shop to tune the truck, it worked fine for about month than he started getting codes coming up. The shop he took it to couldn't fix it and eventually told him to pound sand essentially.
    I got the truck running and driving fine with no codes and no dead pedal or any other issues but after a while it will get a reduced power message and the speed will be limited to 90kmh ish. No matter what I set the values to I can't get rid of the limiter and I don't know how to get rid of the message. It doesn't show any codes when I scan it though.
    Any help would be greatly appreciated. Also willing to compensate for your time if need be.
    Thanks,
    ~Chad
    Dec 2005
    Look at B2852 .
    2011 LML 3500HD CC D/A 4x4
    2006 LBZ 3500 CC D/A 4x4 Sold
    2001 LB7 2500HD D/A 4x4 Sold
    Aug 2014
    Quote Originally Posted by Biodiesel66 View Post
    Look at B2852 .
    When I turn that off I get a dead pedal.
    Lifetime Member Road's Avatar
    Feb 2015
    Quote Originally Posted by BigCE View Post
    Then better check that you have the correct base file. Also revisit your dtc table unless the only thing missing is the egr valve. I don't have my v2 with me I would bet too many modules are communicating too.
    Aug 2014
    Quote Originally Posted by Road View Post
    I'll have to have another look at the DTC codes.
    I'm pretty sure it's the right file, I had one where every single segment matched. Another guy told me it must not be the right file so he recommended I pay the $50 for the ridge runner base file which I did and it was the exact same file I was using. Still same problem.
    This has been an ongoing issue but the truck was getting painted over the last few months so now we're back at it.
    Jan 2006
    Try this, this is the diff between yours and my old 2011 that was happy
    Comparison summary: 02:17:30 pm, Sunday Jun 05, 2016
    Calibration comparison between Base Delete_0009.ctz and 2011 3500 .ctz.
    *Values that differ by more than 0.000100% are considered different.
    B2002 "DEF Low, Speed Limit 1" -21.210364 "CAL: 98.2 <-> ALT: 55.0"
    B2001 "DEF Low, Speed Limit 2" -21.210364 "CAL: 98.2 <-> ALT: 55.0"
    B2000 "DEF Low, Speed Limit 3" -46.266060 "CAL: 98.2 <-> ALT: 4.0"
    B0608 "Speed Limit Fuel Reduction, Normal" 16.666667 "Different from cell: 0,0 to cell: 14,3 inclusive."
    B2009 "SCR Error Warnings" N/A "CAL: Disable <-> ALT: Enable"
    B2010 "SCR Reduced Power Warning" N/A "CAL: Disable <-> ALT: Enable"
    C0001 "DTC Activation Table" N/A "Different from row 22 to row 359 inclusive."
    04 LB7
    2010 LMM
    2015 LML
    Aug 2014
    Thanks for having a look. I sent you a PM. Most of the difference are the speed limiters settings. I changed those in a last ditch effort to bypass the limp mode speed limiter. Anyway I am curious what the differences are in the DTC table.
    Also an Update.
    I think the truck had/has a bad map sensor which may or may not be causing all my problems. Owner has the truck now will confirm if that was the problem next time I work on it.
    Jan 2006
    Did you ever get this sorted out?
    04 LB7
    2010 LMM
    2015 LML
    Jan 2015
    PM me If you still having problems
    08 LMM CC Dually
    Canada
    Aug 2014
    Quote Originally Posted by LMMPerrona View Post
    PM Sent
    Not much of an update I haven't seen the truck for about 3 weeks. The owner got the map sensor wiring fixed and that stopped it from going into limp mode but I believe he is still getting the "reduced power message".
  1. Replies: 13
    Last Post: July 1st, 2014, 02:38 PM
  2. Replies: 1
    Last Post: March 10th, 2013, 05:34 PM
  3. Replies: 3
    Last Post: March 6th, 2011, 02:12 PM
  4. Catching "Reduced Power" Mode for Conversions
    By S10Wildside in forum Conversions / Aftermarket Parts
    Last Post: January 30th, 2011, 09:51 AM
  5. COS 3 auto VE and boost (reduced engine power")
    By blazinblue in forum Gen III V8 Specific
    Last Post: September 13th, 2010, 03:10 PM
