Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Need another license to go from eli live to hp tuners and back to efi live?
    Pull the PCM out and look at the label on it, the Serial Number is printed on there under the bar code. If the number matches what is showing as the current serial number in the software then the PCM has been swapped.
    Nov 2007
Name:	efi live screenshot.png
    Connect your V2 to your PC, then in V8 S&T click on the Licenses button, then click on the VINs tab, and post a screenshot.
    So how many more licenses am I going to have to purchase for this PCM? I have tuned 4 vehicles with my efi live, my 2 duramax's, my camaro and my dads suburban, the only time the pcm has been removed from the camaro was when I had it flashed 2 weekends ago.
    Nov 2007
ID:	19855Click image for larger version.
    Here are the pics of the pcm. The hardware # matches whats in the tune. It looks like the cover has been taken off the pcm, I assume this is something EFI connection does to get the LSX pcm to work on LTX's. So is there something that EFI Connection or HP tuners did to the pcm to change the serial number, cause I know that this pcm hasn't been out of the car since I swapped to the 24x system.
    Can you confirm why the PCM was opened by the tuner? If the main circuit board of the PCM was swapped out for a different one then basically it is a different PCM, just with the same aluminum enclosure. I'm not sure why the core would need to be swapped. Or maybe just the chip was replaced on the main board. Either of those things can cause the serial number to change.
    If you can please let me know the explanation your tuner gives you to explain why the serial number was changed then we will most likely replace the VIN license free of charge.
    Contact me directly at paul@efilive.com if you'd prefer to continue this discussion privately.
    Quote Originally Posted by SS Duramax View Post
    You dont have to take the pcm about to make it work with Lt1's it's just changes in the tune. I use HPT and EFI both daily in vehicles and on my bench harness and flash the same pcm with both software's all the time. Whatever you have going on isnt from it being flashed with efi IMO. I wont go into detail about each software licensing strategies BUT will say with EFI you will very, very rarely ever have a license issue compared to HPT due to how HPT does licensing.
    Jan 2010
    The first post shows it had a custom operating system. 2020005
    If the ECU was not replaced, How did the tuner flash over it with HPT?
    Quote Originally Posted by 1FastBrick View Post
    Good point.
  1. Hp tuners to Efi live
    By madmax4499 in forum E37, E38 & E67 PFI ECM's
    Last Post: October 13th, 2012, 05:51 AM
  2. Is HP Tuners better for gas engines than EFI Live?
    By Texas Edition in forum Petrol / Gas
    Last Post: August 13th, 2012, 08:38 AM
  3. Why 2 Buy EFI Live instead of HP Tuners?
    By DMAX432 in forum General (Diesel)
    Last Post: May 24th, 2010, 05:31 PM
  4. EFI Live / HP Tuners stacked
    By SRT10KLLR in forum E37, E38 & E67 PFI ECM's
    Last Post: December 9th, 2009, 09:52 AM
  5. EFI Live Tuners in Perth?
    By 4wheelin in forum Gen III V8 Specific
    Last Post: September 27th, 2009, 11:38 PM
