Results 1 to 5 of 5
Thread: 3 bar map - going lean when fully loaded
    Member badls1's Avatar
    Dec 2009
    Default 3 bar map - going lean when fully loaded
    Recently swapped to 3 bar map. Adjusted scalar and can read via scan tool to 255kpa. Went to the track last night and running under 199 kpa, tune is clean and runs well. bumping the boost past 199kpa and I am seeing a huge lean spike and injector duty drops once the car is fully loaded, end of 2nd and after clicking third (th400). I am at 200-204 kpa through first and second gear, but only once shifting to third, with no change in boost I see the lean spike. Fuel pressure is consistent through run. I am using an EFI source old style GM 3 bar map sensor.
    I will attached log and tune files shortly. Below is a screen shot of what I was seeing (AFR is green line). Almost like it pointing to a zero cell somewhere in VE table but there are none.
    1989 Notch l Forged 5.3L l PT91.5 l th400
    SBE 4.8L l S475 l th400 8.62@156 (old setup)
    Post tune/log files.
    Dec 2009
    Tune and log files attached
    Base Tune_051416_v3.ctz
    Log_0026.efi
    What injectors are you running...?
    What power are you making at flywheel...?
    Log injector pulsewidth and duty cycle to see if injectors are running out.
    Dec 2009
    Injectors are not running out. There 80lb and fuel pressure is staying constant at 60+psi. Injector duty drops when it goes lean though. Only 60-70% duty. Prolly only making 600 ish flywheel hp.
  1. Updating 2 bar to 3 bar map sensor
    By badls1 in forum Gen III V8 Specific
    Last Post: November 2nd, 2015, 12:40 PM
  2. Tuned as a 2 bar MAP but is actually a 3 bar
    By barbermi in forum Gen III V8 Specific
    Last Post: March 22nd, 2012, 03:24 PM
  3. COS 3.3 bar map only reading 2.5 bar
    By BAD BOB in forum FlashScan V2
    Last Post: August 8th, 2011, 12:27 PM
  4. 3 Bar MAP sensor doesn't work with 3 Bar scaling!
    By Redline Motorsports in forum General (Petrol, Gas, Ethanol)
    Last Post: April 27th, 2010, 05:21 PM
  5. Lean startup with 2 bar SD tune
    Last Post: September 21st, 2006, 10:28 PM
