Thread: Lb7 timing tables
    Apr 2016
    Default Lb7 timing tables
    Can someone explain the timing tables to me. -45 to 45 on base timing. And -45 to 45 on timing after main pulse. Let's say for example there is a 10 in both cells. Does that mean the pilot gets injected 10btdc and then 10 degrees later the main pulse gets injected. Which would mean main pulse gets injected at 0 btdc. For some reason I can get my head wrapped around these. I'm use to gas ignition timing and for some reason the efi live descriptions confuse me
    Mar 2009
    For LB7 the main injection timing tables is what teh table says, then the pilot tables is how far before the main injection.
    Apr 2016
    Read below please
    Apr 2016
    Ok answer this and it should clear it up for me. For example
    Ignition timing base C B0910 0throttle 2400rpm = 8 degrees
    Ignition timing after pilot D B0929 0throttle 2400rpm = 9 degrees
    Answer this in crank rotation BTDC and ATDC when is pilot and when is main injection with my above example.
    The way EFI Live is worded this would make pilot 8degrees BTDC and main would be 1degree ATDC
    Mar 2009
    Quote Originally Posted by TravisF View Post
    The main shot will be at 8 degrees, the pilot shot will be at 17 degrees. The timing for the main injection will always follow the appropriate timing table and limiter/modifier, then pilot timing is ADDED to that.
    Apr 2016
    Thank you. Right before you posted I found out the hard way by putting a 45 in my idle table and then going back in and putting a -45 in to see what was actually happening. Thank you though
    Is there anything else in the lb7 tables to be aware of that the descriptions are incorrect. Like how tables b and d are reversed in the al5 shift pararameters. Anything else to be aware of that are opposite or incorrect.
  1. Timing correction tables
    By rcr1978 in forum Duramax 2011+ LML / LGH
    Last Post: April 10th, 2017, 07:01 AM
  2. MAF Timing LB7
    By LB72004 in forum Duramax LB7
    Last Post: March 1st, 2012, 08:28 PM
  3. DOWNshift timing tables. ???
    By killerbee in forum Allison 5 & 6 Speed
    Last Post: November 3rd, 2011, 05:20 PM
