Results 11 to 20 of 21
Thread: June 2016 Release Candidate 1
  1. #11
    there was an error message about the minimum vve zone has to be bigger than 3x3 (and I'm sure it was)...
    Setting the "Zone edge align" to 1 or greater will expand the zone by that many cells around the edge. So expanding a 1x1 cell by 1 cell in all directions will expand it to a 3x3 cell. That may help in future.
  2. #12
    Hi Joe,
    Can you email me the file and a sequence of step to reproduce the problem?
    I'll try to reproduce the steps... (we were in the dyno room til 4am )
  3. #13
    Could you close the file without saving it? Not sure why you would need to kill the tune tool.
    When I tried closing the file, it would push me to a save dialog, which when I tried to save it would pop up that error... so then I would try to close the file...
  4. #14
    Ok, thanks, I'll keep this in mind.
  5. #15
  6. #16
    Hi Joe,
    Attached is the tuning file just before this happened.
    We were tuning B8101 on engine dyno (MAF/NBO2 not present, MAF DTC present);
    the steps to cause the problem were this (from my 3 am memory):
    - copied B8101 to B8102, B8151, B8152, and I think we forgot to generate coeffs on those 3;
    - tried to save file, but that error message popped up.
    When I'm trying it now on my laptop I can't reproduce it...
  7. #17
    Zones 12..17 defined by rpm 1600..1800 are only 2 cells high. Zones must be at least 3 cells in both directions. That is what is causing the problem.
    Maybe on your laptop you have the "Zone edge align" set to 1 or greater. That has the effect of expanding the zones by one cell on each size.
    Zone too small:
    Zone expanded using "Zone edge align=1"
    P.S. I'm still not sure why you couldn't have just elected not to save the file and closed EFILive that way. I don't get why you had to use task manager.
  8. #18
    Feb 2006
    can i put in a request to change the table display format on the e40 stuff.
    it's annoying as all hell having the rpm along the top and map on the left, when every other ecu is the opposite way around.
    Specifically the 12599861 (1bar & 2bar) calibration. If your in the mood, can you also add the enable flex fuel option, like you did for the e38.
  9. #19
    Ah, I see (it was late and we were losing our minds). Thanks.
    I'll retrace our steps on my customer's laptop, I want to get you more details of this.
  10. #20
    Quote Originally Posted by Tre-Cool View Post
    Yeah, I know, it's the only one that is transposed.
  1. Release Candidate 10, Mar 11, 2012
    Last Post: March 28th, 2012, 12:52 AM
  2. Release Candidate 9, Feb 09, 2012
    Last Post: March 14th, 2012, 04:18 AM
  3. Release Candidate 8, Jan 06, 2012
    Last Post: March 4th, 2012, 02:39 AM
  4. Release Candidate 7, Dec 22, 2011
    Last Post: January 4th, 2012, 07:12 PM
  5. March 05, 2011 release candidate 2
    Last Post: March 20th, 2011, 02:36 PM
