Results 1 to 4 of 4
Thread: V1 cable and end of life ECM question
    Mar 2009
    Default V1 cable and end of life ECM question
    It's been awhile since last time I have been on, I see they have out moded some PCM's. Here's my question, I have a friend that asked if I can get into a 2004 caviler and do some tweaks and reflash it. I still have the v1 flashscan cable, Is it possible?
    Shawn
    98 silverado 4wd excb 5.7l, zz4 cam,roller rockers, shorty headers, 0411 swap, Flash Scan V1 commercial
    Lifetime Member limited cv8r's Avatar
    May 2005
    It's all good until it goes "Bang"
    Mar 2009
    Thanks, however I dont know if I can connect and reflash if I buy a licence. Can I only do the vehicles listed on the above link?
    Quote Originally Posted by haulinit View Post
    Yes, with a FlashScan V1 you can ONLY tune the vehicles listed in the link limited cv8r posted. If you want to tune newer vehicles (anything that is CAN-communications protocol based or Dodge), you'll need to upgrade to a FS V2 which is $499. This allows you to transfer your unused and used PCM licenses to the new FS V2 (if you have 1 used/1 unused on V1, you transfer them to the V2 which comes with 2 new VIN licenses for a total of 1 used/3 unused).
    You can connect and try to read the tune out before purchasing a license, you only need to license the PCM when you go to reflash it for the first time. I'd suggest reading the tune and making sure you can do what your buddy wants then purchasing a license.
  1. GM End of Life Controllers
    By cindy@efilive in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: March 21st, 2016, 03:13 PM
  2. GM End of Life Controllers
    By cindy@efilive in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: March 21st, 2016, 03:12 PM
  3. GM End of Life Controllers
    By cindy@efilive in forum Vortec V6/V8 Specific
    Last Post: March 21st, 2016, 03:11 PM
  4. GM End of Life Controllers
    By cindy@efilive in forum IL4, 97-01 PCM and 02+ P11 PCM
    Last Post: March 21st, 2016, 03:10 PM
  5. What is End Of Life Controllers? Can I still tune an 03 trailblazer?
    By mvvette97 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 3rd, 2016, 06:10 AM
