Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: June 2016 Release Candidate 2
    Default June 2016 Release Candidate 2
    Please download and install both the V7.5 and V8 software packages.
    Both the V7.5 and V8 software were updated in Release Candidate 2, you should download and install both V7.5 and V8 software packages.
    Release Notes:
    Version Numbers:
    After installation, you should have the following software, boot block and firmware versions installed:
    EFILive V7 software: V7.5.7 Build 308 To view the installed version, select Help->About (in the V7 Scan or Tune software).
    EFILive V8 software: V8.2.2 Build 301 To view the installed version, select Help->About (in the V8 Scan and Tune software).
    Boot Block: V2.07.007 (Feb 07, 2014
    ) To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
    Firmware: V2.07.101 (June 06, 2015
    ) To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
    Known Issues
    Issue 1:
    Workaround:
    None.
    It is a restriction of the *.efi (V7.5 log file format). That restriction will be removed and the TCM PIDs will display their true origin once the V8 scan tool software is available and fully integrated with the V8 tuning tool software.
    Issue 2:
    When logging DMA PIDs (i.e. PIDs whose names end with "_M" or "_DMA"), if the ignition is switched off for an extended period while data logging but data logging is not terminated, then when the ignition is switched on again the data log automatically continues. However the DMA PIDs may no longer return valid data.
    Workaround:
    EFILive recommends stopping the data log and restarting the data log when switching off the ignition for extended periods.
    Issue 3:
    The V8 software shows the checksum as incorrect for some CME tune files even when the checksum is correct.
    Workaround:
    Fixed in V8 RC2 Update 1.
    Issue 4:
    When an LMM tune file with operating system 12620015 is loaded into V7.5 no calibrations are available.
    Workaround:
    Download the attached 12620015.calz file and save it into the folder: \Program Files (x86)\EFILive\V7.5\Calibrations\E35, overwrite the existing file, you may need admin privileges to overwrite the existing file.
    Nov 2005
    Software in first post has now been updated.
    Cheers
    Cindy
    Quote Originally Posted by cindy@efilive View Post
    Cheers
    Cindy
    Thanks for the heads up.
    Mar 2011
    I received this error when I was trying to open BBX on an Autocal for a customer using RC2. Have not come across this one before. Have uninstalled, downloaded new copy and reinstalled RC2.
Name:	EFLive Error.PNG
    Quote Originally Posted by mrmanners View Post
    That error occurs when you have a non *.bbx file that has been saved (or renamed) with a *.bbx extension. True *.bbx files contain multiple config files. If any file is named with a *.bbx extension that does not have all the required config files inside it, then you will see that error.
    Mar 2011
    It throws that error before I am able to select a bbx file.
    If the most recently used BBX config file has mistakenly/accidentally got a *.bbx extension then, when EFILive automatically tries to load that config file when you open the BBX window, it sees the *.bbx extension and attempts to load it as a bbx multi stream file instead.
    Close all EFILive software and open the file:\My Documents\EFILive\V8\Config\EFILiveScanAndTune.ini using Notepad.
    Look for the section [MRU Files] and the key "Options". That is the file that is automatically loaded when you open the BBX window. If that file name ends with *.bbx then that is why you see the error.
    Remove that line from the *.ini file using Notepad then re-save the ini file.
    Restart the EFILive software.
    Mar 2011
    Thanks Paul, I will take a look.
    Jun 2016
    Hello Paul
    I have some problems running the EFI Live tune tool. I run windows in VMware, but I have never experienced problems running programs.
Name:	Skjermbilde 2016-06-23 kl. 10.57.55.png
    Jun 2016
    Quote Originally Posted by EspenT View Post
    Hello Paul
    a "touch calc_pids.txt" from bash crated a empty file and that seems to do the trick Is that file missing in the installer? Does it contain important data?
  1. June 2016 Release Candidate 1
    Last Post: June 13th, 2016, 10:44 AM
  2. May 2016: EFILive Beta 3 Test Release
    By Blacky in forum EFILive Beta Software
    Last Post: June 6th, 2016, 07:30 PM
  3. March 2016: EFILive Pre-Release
    Last Post: April 7th, 2016, 07:32 PM
  4. Known issues with the March 2016 Pre-Release
    Last Post: March 23rd, 2016, 05:16 PM
  5. March 05, 2011 release candidate 2
    Last Post: March 20th, 2011, 02:36 PM
