Results 21 to 30 of 37
Thread: June 2016 Release Candidate 2
  1. #21
    Can i add a feature request to enhance the program either in 7.5 or for v8?
    Currently in the scanner properties you can set a default pid or dashboard layout.
    Attachment 19970
    What i think would be a handy thing to add would be to have a Default Pid file selection based on controller & if the auto transmission selection box is selected on the ecu connection screen it will load an alternative (auto) pid. Limit it to 4 or 5 controllers (if it means less coding)
    Attachment 19971
    To save you from adding in every controller currently supported in efilive in the above screen, create a new tab window where you tick or select what controllers you want to be enabled for the above screen.
    Does this sound like a good idea?
    +1 I like that suggestion.
    And have same concept for loading dashboards.
  2. #22
    Currently in V8 there is no option like you suggested, to load an a dashboard based on the controller and an alternate dashboard based on the the "Auto" checkbox. But it is a good idea, I will add that to the "to do " list
    Meanwhile in V8, the dashboards, PID selections etc have been completely redesigned. Using the V8 scan tool, simply load your log file, then select the appropriate dashboard from the drop down list of the 10 most recently used dashboards. The "dashboard" file contains all the PID selections, chart layouts, gauge layouts, maps, in fact everything that can be configured for a dashboard is loaded instantly when you select a new/different dashboard.
  3. #23
    I like that too, 10 MRU dashboard's
  4. #24
    Dec 2005
    Paul,
    Can you elaborate on this change.
    Build 301 Enhancements:
    When opening *.bin and *.ctz files the contents are now validated to that the data in the file matches the data expected for the controller type. If data is missing then the file will fail to load into the software.
    www.mscservices.net
  5. #25
    Paul,
    Firstly the message should have said: ... now validated so that the data ...
    If a *.bin file contains less data than is expected/required for a particular controller type then the file is not loaded and an error is displayed. If you attempt to load a *.bin file that is too short then you will now get an error message and the file won't load. Previously if a *.bin file was short the binary image was padded with $FF's to the required length and everything continued as normal. The reason it was done that way was because the checksums would detect the invalid $FF data and the checksums would show that the data was invalid. Unfortunately that meant a user could choose to correct the checksums (against all the warnings) and flash the file causing bad things to happen.
    It is unlikely that a *.ctz file would be short because the *.ctz file layout and size is strictly managed by the EFILive software. It would only be short if there was a bug in the EFILive software that cause a *.ctz file to be saved with not enough data. But at least if that ever did happen the fault would be detected and the user notified.
  6. #26
    Lifetime Member izaks's Avatar
    Aug 2003
    The "flex fuel" upgrade no longer works with RC2. Using the switch to activate timing retard for nos, is always active, irrespective if switch is on or off.
    Timing is always retarded
    2011 VE SSV 419 + CAM + Whipple 2.9FF SC + PPV front struts + Bilstein rear shocks + 6L90E with single piece carbon fiber prop
  7. #27
    Quote Originally Posted by izaks View Post
    What controller are you referring to? LS1B? If yes then I don't know what is wrong because that has not been touched for years.
  8. #28
    Aug 2003
    E38
    OS 22624402
    CAL 12624488
    Set B5145 to all zeros and timing came back
  9. #29
    And what is the date shown for the .calz when you load it up? Mine is showing 18th December 2015 for 12624402 and one year older for the COS, meaning if something isn't working then it has been like it since then which doesn't seem right.
  10. #30
    Aug 2003
    22624402.calz
    ver 7.59
    date 29th May, 2014
    I will do some testing tomorrow with different versions and let you know.
    I tuned the car before RC2 and the switch worked, pulling timing when activated
  1. June 2016 Release Candidate 1
    Last Post: June 13th, 2016, 10:44 AM
  2. May 2016: EFILive Beta 3 Test Release
    By Blacky in forum EFILive Beta Software
    Last Post: June 6th, 2016, 07:30 PM
  3. March 2016: EFILive Pre-Release
    Last Post: April 7th, 2016, 07:32 PM
  4. Known issues with the March 2016 Pre-Release
    Last Post: March 23rd, 2016, 05:16 PM
  5. March 05, 2011 release candidate 2
    Last Post: March 20th, 2011, 02:36 PM
