Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 37
Thread: June 2016 Release Candidate 2
  1. #11
    Quote Originally Posted by EspenT View Post
    a "touch calc_pids.txt" from bash crated a empty file and that seems to do the trick Is that file missing in the installer? Does it contain important data?
    That file contains user defined calculated PIDs. It won't cause any problems if it is empty. However, the reason that it is missing might cause other problems.
    EFILive stores the names of the folders in which all the configuration files are stored in the registry here:
    \\HKEY_CURRENT_USER\Software\EFILive\V7.5\Properti es\Dir
    You may need to manually change those folder names to match where the files were actually installed (My Documents\EFILive\V7,5\...).
  2. #12
    Jun 2016
    Hi and thank you for your answer. The paths in \\HKEY_CURRENT_USER\Software\EFILive\V7.5\Properti es\Dir appears to be correct. Also all other files where created correctly by the installer
Name:	Skjermbilde 2016-06-24 kl. 09.11.21.png
  3. #13
    Lifetime Member vortecfcar's Avatar
    Apr 2007
    Error report during .cax usage on a custom axis definition. Even though I've adjusted my settings I continue to get an error. The .cax simply makes editable one of the axis in an existing efilive defined table.
Name:	Properties for overlap.jpg
ID:	19945Click image for larger version.
Name:	Overlap error.jpg
    Nick
  4. #14
    Aug 2010
    Only one cax exclusion - that's not too bad. I get a dozen plus cax exclusions happen on both E67 and T43 operating systems.
  5. #15
    Jul 2003
    custom axis definition? how did you manage to change those?
  6. #16
    Quote Originally Posted by vortecfcar View Post
    Is it because the cax overlaps an existing table (rather than the OS or other cax definitions)...?
  7. #17
  8. #18
    Nick
    Can you send me the definition for that calibration? I'll check which EFILive cal it is overlapping and why.
    Send to paul@efilive.com
  9. #19
  10. #20
    Feb 2006
    Can i add a feature request to enhance the program either in 7.5 or for v8?
    Currently in the scanner properties you can set a default pid or dashboard layout.
    What i think would be a handy thing to add would be to have a Default Pid file selection based on controller & if the auto transmission selection box is selected on the ecu connection screen it will load an alternative (auto) pid. Limit it to 4 or 5 controllers (if it means less coding)
    To save you from adding in every controller currently supported in efilive in the above screen, create a new tab window where you tick or select what controllers you want to be enabled for the above screen.
    Does this sound like a good idea?
  1. June 2016 Release Candidate 1
    Last Post: June 13th, 2016, 10:44 AM
  2. May 2016: EFILive Beta 3 Test Release
    By Blacky in forum EFILive Beta Software
    Last Post: June 6th, 2016, 07:30 PM
  3. March 2016: EFILive Pre-Release
    Last Post: April 7th, 2016, 07:32 PM
  4. Known issues with the March 2016 Pre-Release
    Last Post: March 23rd, 2016, 05:16 PM
  5. March 05, 2011 release candidate 2
    Last Post: March 20th, 2011, 02:36 PM
