Page 4 of 4 FirstFirst ... 234
Results 31 to 37 of 37
Thread: June 2016 Release Candidate 2
  1. #31
    Lifetime Member izaks's Avatar
    Aug 2003
    Both build 308 and 309 have date of 29th May 2014
    2011 VE SSV 419 + CAM + Whipple 2.9FF SC + PPV front struts + Bilstein rear shocks + 6L90E with single piece carbon fiber prop
  2. #32
    I don't know what to say Izaks, the E8 files have not been altered at all in RC2 from what has been there for a long time. The actual patch data hasn't changed since 2009.
    Are you able to log the Ethanol sensor status (percentage) when changing the switch to see that it is changing? The timing maps are not part of the upgrade patch, they are just looking at the reported E85 %.
  3. #33
    Aug 2003
    Started from scratch with the standard OS, did the upgrade and the timing is always being subtracted whether the switch is on or off (E85 shows as 85% with switch activated, and 0% when off)
    This was with build 309.
    Can't find the original logs where it worked, as it was at least 6 months ago.
    I will try in out on another car and see if I can get closer to the cause.
  4. #34
    Nov 2013
    I post rarely but read quite often to keep on top of what's going on with updates. My V2 Bootblock/Firmware/Software is listed below and would like to know if there are any other steps involved with updating my V2. Should I update incrementally or can I update to the current software and be OK, any input is appreciated.
    Current Boootblock/Firmware/Software
    Model-FSV2
    Bootblock-2.07.07 February 07, 2014
    Firmware-2.07.64 July 19, 2014
    Thanks,
    Mike
  5. #35
    Quote Originally Posted by COSMOS View Post
    Model-FSV2
    Thanks,
    Mike
    You can update to the latest stable release, available here: http://www.efilive.com/latest/cat/download-efilive
    You don't need to install any intermediate releases, just the most recent one.
    You don't need to uninstall first, you can just install over the existing installation.
  6. #36
    Nov 2013
    Thanks, I'll give it whirl tomorrow morning.
    ~Mike~
  7. #37
    Aug 2003
    Quote Originally Posted by izaks View Post
    A seriously dumb moment.
    I had a value of 1 across the board for B5145, instead of only the cell for 80% Ethanol !!!
    Everything working fine.
    Apologies
  1. June 2016 Release Candidate 1
    Last Post: June 13th, 2016, 10:44 AM
  2. May 2016: EFILive Beta 3 Test Release
    By Blacky in forum EFILive Beta Software
    Last Post: June 6th, 2016, 07:30 PM
  3. March 2016: EFILive Pre-Release
    Last Post: April 7th, 2016, 07:32 PM
  4. Known issues with the March 2016 Pre-Release
    Last Post: March 23rd, 2016, 05:16 PM
  5. March 05, 2011 release candidate 2
    Last Post: March 20th, 2011, 02:36 PM
