Results 1 to 3 of 3
Thread: Remove DBW
    Jun 2016
    Default Remove DBW
    Hello,
    We fitted a holden 5.7 in a nissan drift car, I upgraded from OS 12592433 to OS 04140003
    I disabled O2 sensors + MAF. The car has a few codes but works rather fine.
    I would like to disable DBW and use a mechanical Throttle Body, is it possible and if it is can you tell me how?
    John
    Lifetime Member johnv's Avatar
    Jan 2005
    As far as I know, to convert to cable TB, you would have to swap computer and loom over from a cable TB engine.
    Back yard boost
    347+ T76 = 770 rwhp 10.96 @ 135 mph
    it can be done. just need to wire in the iac/tps sensors as the 1mb ls1 ecu can still run cable throttlebody.
    or just put another ls1 harness on it with them on it.
  1. how to remove maf
    By streetracersgd in forum E37, E38 & E67 PFI ECM's
    Last Post: January 22nd, 2016, 05:30 AM
  2. Remove speed limiter LMM
    By buzzy58 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 8th, 2011, 03:55 PM
  3. 97-98 remove drive by wire
    By v8vegaman in forum General (Petrol, Gas, Ethanol)
    Last Post: September 14th, 2007, 01:37 AM
  4. Should I remove the resistor out of my SLP MAF
    By esco35m in forum Gen III V8 Specific
    Last Post: August 11th, 2007, 09:11 AM
  5. help i cant remove speed limiter
    By 5.3 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 13th, 2005, 01:14 PM
