I'm working on two problems. However, I'm sure you will find others. 1) lean spike on quick initial throttle movement; and 2) KR under boost but it is not constantly happening. I'm a beginner with tuning and efi live and I'm struggling to get any further with my tune. I have attached the current tune and most recent log file.
Problem #1 - I think I'm slowly working it out by increasing B3426 and adjusting B3428 to blend the rich spike into the normal commanded fuel. But please, any more tips would be great.
Problem #2, I have NO CLUE what to do.
Thanks in advance. Here are the detail on my car:
408ci LQ4
9.2:1
317 heads, stock valve size
Cam is 232/238 .612/.615 116+2 114icl
Twin PT 6776, .70/.81ar ball bearing
E-Boost 2 with dual solenoids
Ls6 intake
ZR1 3 bar map
Bosch O2 Sensors (front only)
No MAF
Stock ls1 throttle body
FIC 1000 injectors
Pump gas, no meth spray
0411 ECU 99-02 f-body pin outs
Innovate LC-2 wideband
