Also, make sure to enter all the injector data from the FIC datasheet.
You have STFT trimming on stoich cells in B3647 (aka semi open loop, SOL)(i.e. OL STFT on stoich)... this will skew your wideband data.
you can disable SOL by setting the 1.000 EQR cells to values slightly off 1.000, e.g. 1.088 or 0.99.
wideband also shows that in spite of STFT's, idle is way rich...
so, disable SOL, edit the injector tables, and redo the VE table.
Instead of GM.AFR I like to use GM.EQIVRATIO because it is independent of stoich AFR...
the stock GM tune has B3601 set to 14.63 and the LC-2 assumes 14.7, and your tank will propbaly have E10+/-5 in it...
have a look at the pid CALC.WO2BEN (CLC-00-110) in this file: calc_pids.txt from the Calc.VET thread...
it removes the need to know the values of stoich assumed by the PCM, by the wideband, and of what's actually in the fuel tank.
okay. I'm on it as we speak.
Also, in tunetool, go Edit->Properties and set Commanded Fuel to EQratio.
