Results 1 to 8 of 8
Thread: speedo calibration
    Jun 2004
    Default speedo calibration
    Truck is an 06 duramax
    I'm running v7.5 and can't get the speedo to do a fine tuning calibration. It shows the percent correction I need to do to H0101 but the pulses numbers don't show up and I can't manually change H0101. What am I missing here? I can change tire settings so I could guess at those until I get it correct but if there's an easier way I'd rather do it that way.
    Jun 2004
    Ok....I see when I highlight the final drive table it says the calc's don't work on the LBZ and LLY trucks. So I guess I have to figure out those revs/km and put them in manually?
    Jun 2004
    little confused....my revs are correct for the 285/75/16 tire I have on there. It's just not correcting the speedo. What's the trick here to get it to read correctly?
    Dec 2005
    Measure the rear tire, enter the rollout manually and that gets it spot on. Tires vary in height due to weight of vehicle, air pressures, etc. Entering the actual height always works for me.
    www.mscservices.net
    Jun 2004
    I could see a few tenths being the difference between tires but 4 mph? That's inches off. I will however measure it and see what I get. It's like it overshot it....when I'm at 60 my actual speed is 56. It would really help if the fine tune calc's worked...it'd be as simple as entering in speeds and applying it.
    Lifetime Member Road's Avatar
    Feb 2015
    Quote Originally Posted by 0rion View Post
    Just make your own correction factor by mutiplying by the error
    Jun 2004
    speedo is off 6.5% so I would apply that same factor to tire size? What about shift points? Same factor?
    Feb 2015
    Yes but I don't use the shift point correction much. The speedo correction is hit and miss too many variables plus converting from hex to decimal then back to hex leaves room for error. Sometimes just to make corrections.
  1. speedo calibration problem
    By vcls1 in forum Gen IV V8 Specific
    Last Post: November 29th, 2012, 08:20 PM
  2. Holden Speedo calibration
    By rally1 in forum E37, E38 & E67 PFI ECM's
    Last Post: October 19th, 2010, 12:57 PM
  3. Speedo calibration VSS in Scan not same as speedo
    By maudyZ28 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 23rd, 2010, 01:47 PM
  4. Speedo Calibration
    By Mark Barber in forum General (Petrol, Gas, Ethanol)
    Last Post: September 3rd, 2005, 02:32 PM
