Results 1 to 4 of 4
Thread: Surge and stall with dual pumps
    Nov 2011
    Default Surge and stall with dual pumps
    Workin on a 09 6.7 that we did 100% over exergys along with a PPE dual fueler setup. Sometimes when you put the truck into gear it will start surging and eventually stall. The truck does have some rail surge on higher throttle pulls as well. I messed around with the base duty cycle table a bit to see if it would help but it still seems to do it. I have attached the tune file and idle surge datalog. Any help would be greatly appreciated
    Apr 2011
    It looks to me like this could be a cab and chassis OS with a pickup script run over it - a mixture of some pickup and C&C tables/values on a C&C OS. This can work at times, but often times results in some weird quirks like you describe. Cab and chassis trucks can be a little quirky anyway (especially with some limiter changes). In my experience, cab and chassis trucks need to be approached a little differently when tuning, but everyone has their own tuning style. Your idle settings are pretty drastically different from stock which could be a contributing factor. I would recommend comparing this tune to the stock tune and go back to stock on anything idle related that you have changed like main duration, pilot mm3 and duration, pressure, timing, etc, then retest.
    I honestly didn't look at the log in much detail, but adding the RPM PID would be helpful.
    2019 Ram 6.7L 68RFE
    2003 VW Jetta TDI
    Oct 2014
    Rail pressure is way to high at idle.
    Nov 2011
    You were right. I changed up the operating system and it cleared up the issue. Thank you
    Sent from my iPhone using Tapatalk
  1. e39 ecu 6speed auto T43 upgrading stall converter to 3,000RPM hi stall
    By 3L SIDI in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: January 21st, 2015, 04:26 AM
  2. Dual fueler SURGE AT WOT issue ECM overcorrecting? PID LOOP?..Log Inside
    By Dmaxink in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 26th, 2012, 09:18 AM
  3. Is there a way to increase the PWM for the pumps on an LS1?
    By Highlander in forum Gen III V8 Specific
    Last Post: December 8th, 2010, 10:01 PM
  4. EFILIVE Throttle pumps
    By kingna355 in forum Gen III V8 Specific
    Last Post: February 6th, 2010, 03:17 PM
