Results 1 to 6 of 6
Thread: What is needed for a 2/3 bar tune for LS3
    Oct 2010
    Default What is needed for a 2/3 bar tune for LS3
    OS: 12637084
    Cal: 12635862
    I've changed B2101 and B2103 for the 3bar MAP.
    {B2101} MAP Sensor Scaler 312.500000 scaler
    {B2103} MAP Sensor Offset -11.250000 kPa
    Since I'll be less than 14 lbs of boost I will be using the 2bar VVE table
    [{B8103} "Virtual VE Table, 2bar Forced Induction"]
    So what else is needed?
    {B8021} "Operating Zone MAP Boundaries"
    {B8034} Estimated MAP Maximum
    I've been looking over the LSA tune, but dont know how it is configured physically vs a whipple.
    How much power are you expecting to make, and what injectors do you have...?
    You will need to do this:
    - disable/remove MAF (but retain IAT), requires a MAF DTC to show up.
    - disable CL/LTFT/STFT.
    - set up PE to provide sufficient/safe fueling.
    - log data wideband lambda data.
    If engine/ECM is outside of their orginal car, you will need to disable VATS ("Remove VATS" patch and correctly setting VATS parameters).
    Oct 2010
    All stock LS3 w/ LS9 cam, 2.9L Whipple w/ 4' pully, TSP 2" LT's and CAI.
    The injectors are Siemens 63lb Deka Injectors that come w/ the 2.9L Whipple (60 lbs/hr at 3 BAR (43.5 PSI), running at 59PSI)
    I'm looking for 600HP at sea level to the wheels or as near as I can get.
    This is more for tuning and would be reenabled after correct?
    Quote Originally Posted by opcode View Post
    Yes, correct... altho many people ditch the MAF after playing with scaling.
    Which year/model/vehicle is your E38 from (I don't have the OS id's handy at the moment)...?
    If it's earlier than 2009 then the injector tables are limited to 63 lb/hr so will need MAF/VE/IFR scaling; later than 2009 they are 127 lb/hr.
    There are MAF/ETC sanity tables to be looked at also.
    Usually after scaling is tried, MAF is typically thrown away.
    Do you have a stock LS9/LSA tune file for reference...?
    Oct 2010
    I have a 2013 ZL1 and 2012 CTS-V automatic tunes to reference.
    It for a 2010 Camaro SS (LS3)
  1. 1999 camaro, LS3 swap and trouble with pcm files...help needed
    By wmpeekm in forum Gen III V8 Specific
    Last Post: October 15th, 2015, 11:18 AM
  2. 08 LS3 C6 Custom Tune
    By rebel7777 in forum E37, E38 & E67 PFI ECM's
    Last Post: November 4th, 2010, 02:25 AM
  3. Looking for a Stock LS3 tune
    By n8dogg in forum Gen IV V8 Specific
    Last Post: July 28th, 2010, 10:34 AM
  4. A tune for an LS3
    By c55asleep in forum Gen IV V8 Specific
    Last Post: December 30th, 2009, 02:09 AM
  5. 08 Vette LS3, 2 bar map?
    By edcmat-l1 in forum E37, E38 & E67 PFI ECM's
    Last Post: June 4th, 2009, 09:31 AM
