Results 1 to 4 of 4
Thread: Used ECM
    Aug 2010
    Default Used ECM
    Can I replace used ecm LML E86?
    If yes how?
    I have access to tis website.
    I program with the last cal update according New VIN.
    The vtd learn not work.
    Quote Originally Posted by shay View Post
    If yes how?
    Clarify your question. It is not clear.
    Custom Tuning Services
    Aug 2010
    Is there a possibility to replace ECM with a used one?
    Can I also match the VTD with the used one?
    Does the EFILive work for the VTD?
    I tried to use the TISweb but it didn't work
    shay
    Jan 2015
    It will work I just did one. Also mine was E86A (11-14). Dont know about E86B. All i did was lower the time for VATS relearn from 600 sec to 60 sec and relearn count from 3 to 2. I then followed the learn procedure with the new time and counts. It relearned and then i flashed my modified tune. The only reason why I lowered the time is so I dont sit there and drain my battery since it takes forever. Don't know if there is other ways but this way worked for me.
    08 LMM CC Dually
    Canada
  1. Do I need to buy another tuning license for a replacement ecm? Damaged ecm
    By mvvette97 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 15th, 2016, 12:11 PM
  2. Replies: 18
    Last Post: February 20th, 2015, 07:01 AM
  3. pickup truck ECM/van ECM interchange
    By DURAtotheMAX in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 24th, 2014, 07:02 AM
  4. New ECM ? Have question bout vin license an efi live to new ECM
    By Collins in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 15th, 2012, 10:19 AM
  5. Need LBZ ecm, willing to give immacculate LMM ecm as exchange
    By badassmax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 9th, 2011, 04:20 AM
