Page 1 of 8 123 ... LastLast
Results 1 to 10 of 79
Thread: Afr fluctuations with olsd
    Jan 2011
    Default Afr fluctuations with olsd
    Hi all. I have been battling this issue for months now and still can not seem to figure it out. My issue is that the car starts and runs great and idles right around 15.0 but as it warms up eventually gets to about 12.8. I first thought it was something that i had messed up in my tune so I decided i would bite the bullet and buy a tune from a very well known reputable tuner. Well it still does it. I contacted the tuner i bought the tune from and he says that running in olsd that the car will only run off the main ve table so there has to be something else going on with the fuel system. Is he right about the ve table that nothing else will add or subtract when running in olsd? I can post logs if this is not the case and there are other factors that will effect idle afr. Car runs perfect otherwise.
    Aug 2013
    Quote Originally Posted by johnj View Post
    No, he is wrong... and I don't care how well known or reputable he is, if he can't fix your issue then he is a useless tuner and shouldn't be selling tunes.
    Jan 2011
    Well thanks for the reply. Any thoughts on correcting my issue then?
    Aug 2013
    Yeah... fix your Injector Data, then fix your Charge Temperature Blending table, then retune your VE table.
    It's not easily done... which is why your tuner blew you off.
    Jan 2011
    Thanks a bunch I will give that a go.
    Post tune and log files.
    Jan 2011
    Are there any certain pids you would like me to monitor
    eqivratio
    longft1/2
    dynair
    dyncylair
    tp
    rpm
    sparkadv
    kr
    ect
    iat
    ibpw1/2
    edit: and my all uppercase got reformatted to lower.
    Jan 2011
    I have finally gotten some free time to get a log of the car idling. Heres the log and tune.rambler new tune 8.ctz rambler idle.efi
    Your wideband AFR is fluctuating just a little, that's not so bad... the problem is that it is too rich, wb 12.2 vs commanded 14.5.
    Is your VE table corrected...?
  1. Help with OLSD idle????
    By johnj in forum Gen III V8 Specific
    Last Post: April 3rd, 2016, 05:03 AM
  2. IDLE AFR fluctuations
    By maudyZ28 in forum Gen III V8 Specific
    Last Post: April 8th, 2011, 09:31 AM
  3. Could the E38 OLSD tuned ?
    By wesam in forum E37, E38 & E67 PFI ECM's
    Last Post: March 27th, 2011, 07:32 AM
  4. Need help tuning olsd without o2 sensors
    By 02sierra4x4 in forum Gen III V8 Specific
    Last Post: September 28th, 2009, 04:16 PM
  5. Just went from OLSD to CLSD, some questions
    Last Post: July 7th, 2008, 07:53 AM
