Page 1 of 6 123 ... LastLast
Results 1 to 10 of 57
Thread: Why does this engine want to idle at 1500RPM
    Aug 2008
    Question Why does this engine want to idle at 1500RPM
    Stock 6.0 Block
    Brian T Stage 4 Cam With upgraded springs and trunions
    GMPP CNC ported LS3 Heads
    Stock LS3 Intake and Injectors 42lb
    100mm Throttle Body DBC
    Built 4l60e with 3900 Stall converter
    I have updated the Injector Flow Rate, and I have played with all the tables I could think of. ECM was from a 5.3 and I have tried to modify accordingly but for the life of me I can not figure out why the heck this thing wants to ideal at 1500rpm and be a pain in the booty to start. I am ok if someone even says hey dumb a$$ go look at this table or these tables and figure it out. I have been dinking with this for few weeks now and just looking for ideas on where to look for get it running close to normal so I can do the auto tune setup with the wideband.
    Kevin
    TroyZ06.ctz
    Hi Kevin, an airleak would cause the idle rpm to go high like that.
    Aug 2008
    That was my first thought, however it did this with my stock parts. 6.0 stock heads and cam, ls1 intake and injectors...
    I have literally poured brakeclean everywhere trying to find airleak. Not that it probly matters but watching my afr its 14.x to 19.x
    Sent from my SAMSUNG-SM-N910A using Tapatalk
    What PCV plumbing do you have...?
    Aug 2008
    Like old school setup. Filter at the valve cover and capped off on the intake manifold.
    Sent from electronic life sucking device.
    Aug 2008
    Looked at it again just to make sure.
    Drivers side has the valve and a mini filter on it. Passenger side goes out of valve cover to throttle body. Nothing in valley cover.
    Apr 2015
    What valley cover?
    Jan 2010
    What brand of 100MM DBC? is there an adapter plate on it?
    Are you sure it's making a good seal with the LS3 intake? Those intakes were DBW from the factory so I am curious if there is a mismatch in this area allowing air in?
    I know the FAST intake had this issue with there manifolds with certain brands of Throttle bodies.
    Aug 2008
    I lied, holley 90mm and it bolts right up to the stock ls3 intake.
    Aug 2008
    The only problem id have with the bad fit to ls3 is i had this same problem before with all ls1 stuff but same tb.
  1. Problem with surging idle and engine dying
    By JoshH in forum Gen III V8 Specific
    Last Post: October 24th, 2016, 02:45 AM
  2. reduced engine power p1514 KOER set at idle but P1518 set KOEO
    By megadeus in forum Gen III V8 Specific
    Last Post: April 11th, 2015, 08:58 AM
  3. Engine stalling at idle in open loop only
    By genR8 in forum Gen III V8 Specific
    Last Post: September 3rd, 2012, 06:44 PM
  4. Engine RPM vs Engine speed
    By SPi in forum Gen III V8 Specific
    Last Post: August 11th, 2011, 03:09 PM
  5. can a lean idle or going lean during light cruise harm the engine?
    By ryans1000 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 3rd, 2009, 01:44 PM
