Bump, for other ideas, rude comments, name calling, pictures of stuff?
Sent from electronic life sucking device.
Can you post a log of the IAC counts and short and long term idle trims at idle? Is the set screw on the TB cracking the blade open too much?
00 Silverado Z71, LQ9 w/ LS3 heads, BTR cam, Whipple 2.9@8#, 4l80E
I didnt log Iac but can say its adding fuel for the long term as its in the positive, which im assuming would suggest vacuum leak. Im gonna try a different approach to the pcv just to make sure 100% thats not an issue. tps shows its at .4% or .04% off top of my head. I will post the last log i took here shortly.
I was referring to the idle trims, not fuel, those PIDs are in the idle folder/sub-selection. The TPS sensor can be reset to read 0%, so it may be worth looking into. What are your desired air flow values at operating temp? If your IAC counts and/or idle trims are negative, I would back out the set screw on the throttle body. Ideal is 60-80 counts at hot idle.
logs10a.efi
I know that doesn't have probly any helpful info but thats what I was looking at. I'll see if I can get into the shop tomorrow and take a log of those pids.
Thank you for help.
You get a chance to log those PIDs?
s10iac2.efi
Ok here is a log file with a bunch of IAC stuff. It looks like max was 140, 39...
I'll look at when I get home. Can you attach your current tune?
