Results 1 to 4 of 4
Thread: STFT Adding fuel on deceleration
    Dec 2005
    Default STFT Adding fuel on deceleration
    I am getting big + stft on deceleration even when 02s show rich and my wide band goes rich any ideas
    I have turn the 02 sensor setting inside out with efilive and brand x nothing helps after about 60 flashes
    any ideas ?
    Here is a screen shot Click image for larger version.
    Dec 2005
    I turn the dfco back on seems to work much better on gen 5 stuff problem fixed
    Ok, I was thinking it was DFCO... thanks for confirming that.
    Dec 2005
    The dfco was off in that snap shot,If you look it was adding to much fuel
    (stock o2s where in 8xx and still adding fuel )My wide band was showing rich also
    The only way to fix it was by turn the dfco on so it would shut off fuel and not shove max +stft
  1. Adding Flex Fuel Sensor
    By gpr in forum Gen III V8 Specific
    Last Post: March 13th, 2015, 10:40 AM
  2. adding fuel pressure and WB02 into ecu.
    By RADustin in forum Gen III V8 Specific
    Last Post: March 10th, 2015, 04:34 AM
  3. Adding Fuel Pressure to LS1
    Last Post: October 20th, 2013, 07:02 AM
  4. How Do You Achieve Zero Fuel Consumption On Deceleration?
    By neil in forum Tuning For Economy
    Last Post: November 6th, 2012, 09:16 PM
  5. Adding fuel
    By Lennart in forum General (Diesel)
    Last Post: January 18th, 2006, 03:43 PM
