Is HOT refering to the engine being TO HOT? 140c in the mixture parameters. HOT PE mode coolent temp threshold = 140c. 284 F. ( which is pretty hot )
As in the setting for the Hot PE Mode Enable table to work.
Just wanting clarification since in the ls1edit days everyone copied the wot hot table, and wot cold table because they could not get hot to work because of the wot hot temp.
Do we even want hot to work? Should all tuning be done with the normal temps?
OR
Should the HOT temp be lowered to 140f or 60c? basically once the engine warms up the hot temp tables get used.
