Results 1 to 7 of 7
Thread: TU/TD manual control
    Jan 2009
    Default TU/TD manual control
    I'm having an issue with TU/TD function. Scanning the TCU, I'm seeing the request for upshift and downshift but it will not do either. The scanner shows that it's in the manual mode but the driver control always shows inactive. What am I missing? What are the parameters of enabling manual control? The way I see it is that if the shifter sees the manual detent and the TU/TD switch is recognized by the resistance, then it should switch on the scanner to driver control active....... The TU/TD shifter is enabled and set to wired in the software. What am I missing?
    Lifetime Member DURAtotheMAX's Avatar
    Nov 2005
    What vehicle and year...?
    2005 Silverado, CC/SB, 4x4, LT, LILLY/Allison
    12.9s @ 108 mph
    many thanks to Ross and Paul
    Jan 2009
    It's a 2011 L99 6.2L with a 6L80E out of a Camaro that is transplanted into a Jeep-
    Nov 2005
    I thought tap-up/tap-down was controlled via a data message from the camaro BCM? Or did you swap the BCM too?
    12.9s @ 108 mph
    Jan 2009
    The BCM is not required for the Camaro/Corvette OS from my reading at least. The truck OS however.......
    Oct 2007
    Take a look at this thread, you need to wire a set of resistors into pin #7 on the TCM harness.
    http://www.pirate4x4.com/forum/gener...tap-shift.html
    Jan 2009
    Those resistors are already part of the TU/TD switches in the Malibu shifter and are the correct resistance-
  1. Replies: 2
    Last Post: October 22nd, 2013, 10:29 AM
  2. Manual upshift downshift 1,2,3,4 on 4L60e without manual valve body
    By Test101 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: October 7th, 2013, 07:30 PM
  3. Manual AFR control with Scan Tool
    By 2002_z28_six_speed in forum General
    Last Post: September 14th, 2007, 06:23 PM
  4. manual control
    By ASSAMI in forum General (Petrol, Gas, Ethanol)
    Last Post: February 4th, 2007, 12:42 AM
