Results 1 to 3 of 3
Thread: Shift Speed
    Lifetime Member Road's Avatar
    Feb 2015
    Default Shift Speed
    I have seen this on A50 and 6L80 so far.
    The shift speed tables are scaled to 50%.
    This one in particular is a A50 and the wot 3>4 shift speed in the shift tables is set to shift @32 mph and the truck is shifting @64 mph.
    It is setup that way in hpt and live so there has to be a reason it is scaled. Any thoughts?
    Oct 2014
    I've been having some shift speed issues as well. On my personal truck, I've got the part throttle up shifts not working as they are in the table. Today it shifted into 6th @30mph and 20%throttle... not sure what gives or if I'm completely missing something.
    Did you ever figure out your issue?
    2003 LB7 ECSB
    - Not Built, Intake, Mbrp Black Series 5" Straight, Banks Big Head Wastegate
    - Bagged in rear with Air Lift, 305/65/17
    - EFI Live By Myself, Used For Work
    - Sold at 242k
    2011 LML CCSB
    - Stock... For Now
    Feb 2015
    Quote Originally Posted by jgooch1548 View Post
    It is right in the software just the way it is being converted from binary.
  1. LMM TCM shift points - minimum speed for downshift?
    By robof16 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 23rd, 2015, 06:19 AM
  2. 2006 Allison 6 speed shift timing changes
    By cpschevy in forum Allison 5 & 6 Speed
    Last Post: February 19th, 2013, 05:03 AM
  3. No Shift time adjustment in new 6L80E OS? Adjusting shift times in Torque Model
    By Protec in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: February 13th, 2013, 10:34 AM
  4. Shift speed / delay
    By Garry in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: April 13th, 2009, 05:43 PM
  5. Disable adaptive shift learning after Shift Kit Install
    By BlackGMC in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 24th, 2008, 05:49 AM
