Thread: July 2016, Release Candidate 3
    Default July 2016, Release Candidate 3
    Both the V7.5 and V8 software were updated in Release Candidate 3, you should download and install both V7.5 and V8 software packages.
    Release Notes:
    Version Numbers:
    After installation, you should have the following software, boot block and firmware versions installed:
    EFILive V7 software: V7.5.7 Build 309 To view the installed version, select Help->About (in the V7 Scan or Tune software).
    EFILive V8 software: V8.2.2 Build 302 To view the installed version, select Help->About (in the V8 Scan and Tune software).
    Boot Block: V2.07.007 (Feb 07, 2014
    ) To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
    Firmware: V2.07.102 (July 08, 2015
    ) To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
    Known Issues
    Issue 1:
    Workaround:
    None.
    Issue 2:
    Workaround:
    Issue 3:
    The "What's New" release notes displayed in the EFILive V8 software show the firmware date as July 04, 2016.
    Workaround:
    The firmware date should be July 08, 2016.
    Thanks.
    Dec 2005
    I did a read on a t43 and it has a update checksum warning, After reading the info that comes up it seems I can hit the update checksum and save the file it will be safe to use because it had read it from a working car?
    Is this the fix for the checksum err that can happen with a controller that has be modified with other software then you Click image for larger version.
Name:	update checksum.PNG
ID:	20123try to flash it back
    It just says the checksums are disabled (for some reason), not that they are wrong. If they were wrong indicating corruption then you wouldn't fix it, but as they are only disabled then you should be fine to correct them and resave the file.
    EFILive Reseller
    Nov 2005
    I get HTTP 404 not found for the links to the software.
    http://download.efilive.com/Software....7.309_RC3.exe
    www.kennedydiesel.com
    Specializing in Duramax Performance
    More than just a salesman-I use and test the products that I sell on a daily basis.
    Superflow Lie Detector in house
    Quote Originally Posted by Kennedy Diesel View Post
    RC3 has been superseded by the public release here: http://www.efilive.com/latest/cat/download-efilive
    There is also a newer (beta) version available here: https://forum.efilive.com/showthread...a-Test-Release
  1. June 2016 Release Candidate 2
    Last Post: August 16th, 2016, 11:48 PM
  2. June 2016 Release Candidate 1
    Last Post: June 13th, 2016, 09:44 AM
  3. Pre-Release Update July 29, 2011
    Last Post: August 4th, 2011, 08:50 AM
  4. Pre-Release Update July 18, 2011
    Last Post: July 26th, 2011, 11:03 PM
