Results 1 to 10 of 15
Thread: Just one question for now?
    May 2012
    Default Just one question for now?
    Hello everyone.
    LS2 engine with E40 pcm in Australian VZ clubsport.
    My question is in relation to table B3671. The original tune has 14.7 across the board to reflect the stoichiometric ratio of normal unleaded fuel,
    however I am using premium shell unleaded 98 ron which supposedly has a stoichiometric of 14.35. Should this be the value that I populate in that table.
    Thanks again .
    Try it and observe the LTFT's... compare them before/after.
    May 2012
    Thanks, ill let you know.
    May 2012
    Hello Joecar.
    I ended up populating the table with 14.4 for stoich, LTFT's became more negative, not sure how I am meant to interpret this.
    Car feels more responsive and fuel economy has improved.
    Am I on the right track by populating table B3671 with this value.
    14.4 might not be the right stoich AFR...
    yes.
    May 2012
    Can you inform me what the correct stoich AFR is for Australian Premium 98 ron fuel.
    Thanks.
    Aug 2013
    The correct stoich AFR is 14.7 for both regular unleaded and premium unleaded.
    The only difference between regular and premium unleaded is that premium unleaded has a higher RON number. The RON number is an indication of how resistant the fuel is to detonation. The higher RON number means that you can advance the spark timing more before you encounter engine knock.
    There's absolutely no benefit in using premium fuel unless your spark tables are tuned for premium fuel.
    Premium being more knock resistant allows you to run more spark advance and/or higher compression ratio.
    May 2012
    Thanks for the input fellas.
    May 2012
    Hello joecar.
    I did not want to start another thread. Question is.
    In near the future I am going to fit some pacemaker long tube extractors and cat back exhaust.
    I know that I have to delete the two rear NB o2 sensors from the tune as there is no provision for them in the exhaust and I will only be using the NB o2 sensors fitted to each bank on the extractors.
    Now when I come to tune the VE table with a wideband do I need the information from both narrow band sensors? Or can I get away with unplugging one of them, plug my wide band in its place and tune the VE table from there?
  1. Desired Airflow Question, not your normal question
    By Dale in forum General (Petrol, Gas, Ethanol)
    Last Post: October 1st, 2010, 10:10 AM
  2. Locked out timing question for boost setup question??
    Last Post: September 13th, 2005, 02:22 PM
