Results 1 to 10 of 13
Thread: July 2016, Public Release
    Default July 2016, Public Release
    Release Notes:
    Version Numbers:
    After installation, you should have the following software, boot block and firmware versions installed:
    EFILive V7 software: V7.5.7 Build 309 To view the installed version, select Help->About (in the V7 Scan or Tune software).
    EFILive V8 software: V8.2.2 Build 303 To view the installed version, select Help->About (in the V8 Scan and Tune software).
    Boot Block: V2.07.007 (Feb 07, 2014
    ) To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
    Firmware: V2.07.102 (July 08, 2016
    ) To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
    Known Issues
    Issue 1:
    Workaround:
    None.
    Issue 2:
    Workaround:
    Dec 2015
    Wow I didn't know v8 pass through logging was a thing now. What have I been doing with my life? Well done!
    Nov 2005
    Quote Originally Posted by Snipesy View Post
    It was originally added to April beta software, and has had a number of enhancements since.
    Cindy
    Sent from my iPad using Tapatalk
    Aug 2008
    I updated and now have the ECM on my 2013 Locked. Any insight on fixing it? The truck will not start now.
    Quote Originally Posted by S Phinney View Post
    What did you do...?
    Did you use V7, V8, V2 BBx...?
    Aug 2008
    Flashing pass thru via V8 to my ecm. Don't know what happened. First attempt failed with no data transferred and second attempt went thru but as it was flashing the service brake controller, service stabilitrak and other service warnings came up. After that it was done. I could not communicate to flash again. When checking with V8 thru the dtcs and auto detect the ecm has no Vin or serial numbers now. I guess it is permanently done now. This is the only time that I have had a issue flashing this truck or others for that matter. I sent trace files in to support and maybe they can tell what went wrong. On my end I did it the same as a 1000 times before.
    Sent from my SM-G920V using Tapatalk
    Dec 2007
    Full flash a file in that does not have VIN or SN security restrictions and you should be fine. Happens to customers while BBX flashing with AutoCals all the time. If you can communicate through the OBD tab the ECM is likely fine.
    Aug 2008
    Tried it all Dustin! Lorenzo at Socal thought the same until he tried via team veiwer and saw it for himself. Paul with EFI Live says it's unrecoverable with the trace files that he has reviewed..
    What Year, Model, and Controller is it?
    What were you doing that messed up the controller?
    Service # of ECM would help....might be able to fix it for you.
    Chuck CoW
    I
    Aug 2008
    It is a 2013 LML duramax. Everyone says that it's not recoverable. I did not do anything out of the ordinary when flashing a tune but it lost information such as the Vin and ecm serial number and locked new out.
  1. July 2016, Release Candidate 3
    Last Post: August 26th, 2016, 09:51 AM
  2. Known issues with July 08, 2015 Public Pre-Release
    Last Post: July 27th, 2015, 05:59 PM
  3. July 08, 2015: EFILive Public Pre-Release
  4. Public Release Update July 03, 2011
    Last Post: July 17th, 2011, 08:21 AM
  5. EFILive V7.4.2 Public Update - July 22, 2007
    By eboggs_jkvl in forum Lounge
    Last Post: July 23rd, 2007, 02:07 AM
