Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: tcc problems
    Aug 2010
    Quote Originally Posted by danny68ss View Post
    Ok thanks for looking i may be hearing something else i just noticed the rpm jump when i back off the throttle thought it was unlocking the converter
    Yes sir, it is unlocking the TC when you release the throttle - that is what truck tunes do. If you review your logs, when you ease up on the throttle, you will see the TCC status go from "Locked" to "Coast" (which means that it is getting ready to unlock), then to "Off".
    Feb 2014
    Does the torque converter slippage look normal for being locked
    BTW: TSTATE09 and TSTATE10 are particularly useful because they show the reason the TCC is unlocked.
    Feb 2014
    Is that amount of slippage normal while locked
    That's ok and is normal.
    Feb 2014
    Ok i added the other pids and what im hearing is when it go to full lock it only does it at around 30% throttle anyway of adjusting that
  1. TCC Tuning! TCC Lock 3rd at WOT?
    By EagleMark in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 12th, 2013, 07:31 AM
  2. Possible TCC Slip/TCC Tuning?
    By Meister in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: March 29th, 2011, 03:41 AM
  3. Vigilante TCC, TCC PWM, lockups, and you
    By arubenstein in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 21st, 2008, 03:07 AM
  4. Non TCC PWM transmission/converter in vehicle originally wth TCC PWM?
    By 350SS in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 17th, 2007, 07:15 PM
  5. TCC Unlock Problems
    By Rontune in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 7th, 2006, 09:46 AM
