Results 1 to 2 of 2
Thread: How to stop upshift from 1st to 2nd while in 1st gear 2003 silverado
    Lifetime Member mvvette97's Avatar
    Jul 2007
    Default How to stop upshift from 1st to 2nd while in 1st gear 2003 silverado
    Hey guys is there a way to keep my truck from shift out of first while my gear selector is in the first gear location? I was goofing around today and had my tires covered in mud so I pulled out on the hard surface and pulled it to 1st on the selector and held the brake and hammered down, haha. Even though I was in first it still upshifted to 2nd gear while the gear selector was still in 1st gear. It won't hold low gear. I thought I had it set to hold first gear but I must of missed something.
    Look at D0913 and D0928...
    ( M1 means Manual First lever position )
    your D0913 is set to 255 mph, this should not allow the M1 1->2 upshift.
    your D0928 is set to 39 mph, this will cause M1 2->1 downshift if you were in M1 2nd gear and are now slowing down to 39 mph or less...
    D0928 having an attainable value may be allowing M1 2nd (somehow, I'm not sure how...)...
    Try this: set D0928 to 254 mph.
  1. Upshift to 2nd gear when in maual 1st-4L80E
    By mysunnshine in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 17th, 2015, 04:12 PM
  2. LTG 2014 Malibu no full boost 1st and 2nd E39A Hptuners
    By Nastruck in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: November 27th, 2015, 02:31 PM
  3. 1st to 2nd shift slipping at WOT
    By Mayhem in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 21st, 2012, 05:13 AM
  4. Why does 1st gear slam into 2nd? 4L80E translplant
    By 1SlowHoe in forum Gen III V8 Specific
    Last Post: May 22nd, 2010, 09:47 AM
  5. my box will only shift 1st and 2nd
    By trickas in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: August 3rd, 2009, 01:46 PM
