Results 1 to 9 of 9
Thread: 6l80 final drive ration, gearing, and tire change help
    Oct 2007
    Default 6l80 final drive ration, gearing, and tire change help
    I have a 418 stroker and a 6l80 in an offroad race car the ecu and trans came out of a 2007 Yukon denali. This car and trans have gone through many build phases, and the trans tuning IE..shift points have never been right. For some reason my tuner used a final drive ratio of 4.40 and a tire diameter of 36" (when my final drive ratio is actually 5.43, and my tire measures 38.5" tall . I am now using a corvette TCM tune to utilize tap shift. When I flashed this in I changed the shift speeds to match my old tcm tune.
    I want to try to change my final drive ratios so they are correct. When I do this under the TCM speedo section I can change both the final drive ration, and the tire size, but when I press apply none of the shift speeds change. I have also tried to make changes utilizing the shift point corrections tab, and I get a message that says (No transmisison settings are available
    for adjustment in this calibration.)
    Does anyone have any pointers, on how to apply these changes and make them change shift MPH speeds?
    Jared
    Post your trans file.
    Oct 2007
    Here is one of the tunes, I have several variations.
    Is this what you're using to change the shift points?
    Oct 2007
    Yes I am at that screen, but I don't get any of those parameters to populate in the middle section. I get a message stating (No transmission settings are available
    for adjustment in this calibration.) I will try to re-open my tune as it looks like you were able to make the changes to my base tune I had posted.
    Oct 2007
    Blacky prior to me getting to the picture you screenshot I get a box that pops up when I click on speedo calculator that says
    EFI live tune- digital tools for onboard vehicle electronics
    Cannot create file C:\Programfiles
    (x86)\EFILive\V7.5\Configuration\cal_adjust.txt" access is denied
    The cal_adjust.txt file (which contains the list of calibrations to be updated) is stored in the C:\Program Files (x86)\EFILive\V7.5\Configuration folder.
    Windows requires admin privileges for any program (i.e. EFILive) to be allowed to modify any file in that folder.
    So as a quick test, try running EFILive as Administrator. To do that right click on the desktop shortcut for the "EFILive Tune Tool" and select Run as Administrator.
    Oct 2007
    Thanks Paul that seemed to work. Appreciate everyone's help here.
    Oct 2007
    Now for the next question.
    When I open up parameters under the speedo section it shows H0103 final drive ration as 4.40, but when I click on the speedo calculator button it shows my H0103 as 1.11.
    Is this causing the TCM to get a bad reading?
  1. final drive ratio 1.0 corvette issues changing gear ratio
    By v8vegaman in forum Gen IV V8 Specific
    Last Post: October 6th, 2014, 11:24 AM
  2. why cant i change my tire size
    By rebuelta22 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 24th, 2012, 05:56 PM
  3. Tire change
    By 69camaro5speed in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: December 4th, 2011, 01:20 PM
  4. Change a tire ...
    By Garry in forum Lounge
    Last Post: September 21st, 2008, 06:07 PM
  5. front tire change on a C5?
    By Highlander in forum General (Petrol, Gas, Ethanol)
    Last Post: November 1st, 2005, 02:15 PM
