Results 1 to 3 of 3
Thread: One more licensing question................
    May 2006
    Default One more licensing question................
    I bought a used copy of EfiLive FlashScan and when I installed it, it said that there were two available licenses on the cable. Sorry for the stupid newbie question, but does this mean that I can just hook it up and get started?
    The person that I bought it off of had a Camaro, and I've got a Corvette. Does this matter or do I have to buy another license?
    Also, if I put the key into both my laptop and my desktop, and register the cable, does that take two licenses or just the one that is reading the car? I put the cable on both, so I hope that it's not registered to both. I got so excited that I got the software, that I Completely forgot that I could just save the file and transfer it............DUH (It's not my fault, I must've been dropped on my head as a kid ).
    Thanks in advance for your help!
    The key takes no PCM licences, and should allow you to connect the Scan Tool to any GM OBD-II vehicle, and to read from flash from any supported PCM.
    Your cable should have 2 PCM licences, one of which would have been used by the previous owner; from the Tune tool, with your cable/black-box connected, go Help->FlashScan PCM Licencing to see how many unused licenses you have; if you have one, then when you go to write to flash for the first time it will ask you if you want to use this license.
    May 2006
    Thank You!
  1. V1 Licensing Question
    By tatasta in forum FlashScan V1
    Last Post: May 17th, 2009, 08:01 AM
  2. V2 licensing question
    By Spindoctor in forum FlashScan V2
    Last Post: April 10th, 2009, 12:23 PM
  3. Question About V2 Licensing
    By VortechC5 in forum FlashScan V2
    Last Post: November 15th, 2006, 01:58 PM
  4. Licensing question..................
    By FreddyG in forum Purchase and Shipping
    Last Post: May 23rd, 2006, 11:25 AM
  5. Licensing question
    By Cougar281 in forum Purchase and Shipping
    Last Post: February 8th, 2006, 09:39 AM
