Results 1 to 8 of 8
Thread: Deleting Factory VGT Turbo
    Jan 2016
    Default Deleting Factory VGT Turbo
    Hello,
    Can someone please tell me if there is anything I am forgetting for removing factory VGT turbo? I will be installing 363/477 combo soon.
    Thanks in advance.
    Dec 2013
    There are some DTCs regarding turbo errors as well if it is to be removed.
    Nov 2010
    Your not going to find help defeating emissions devices on here or most any forums. Sad to say but it's the way things are
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
    Aug 2008
    Quote Originally Posted by 2007 5.9 View Post
    Since when is a turbo a emission equipment now?
    Sent from my SM-G920V using Tapatalk
    Nov 2010
    Quote Originally Posted by S Phinney View Post
    Anything ahead of the last monitored emissions device is off limits to removal or modifying. So on a 6.7, the dpf is the last and anything upstream is still emissions equipment.
    Hate to sound like a jerk, but I'm sure efi doesn't want discussion of illegal activities on their board. If I'm wrong then I'm sure they will edit or moderate my posts.
    Les Szmidt
    2007 5.9 Dodge Ram
    Jan 2016
    well then by that standard ALL tuning is illegal...
    Nov 2010
    I'm not going to get into semantics here...good luck with finding the info you search for. I'm sure plenty of help could be found via private message...
    Les Szmidt
    2007 5.9 Dodge Ram
    Mar 2016
    You will get rid of faults but it will be a slug a lower rpm without some density remapping
  1. 72mm vgt turbos??
    By Scarface in forum Duramax LLY
    Last Post: August 4th, 2015, 05:32 AM
  2. 07.5 6.7 vgt turbo?
    By Scarface in forum Cummins 6.7L
    Last Post: May 8th, 2015, 03:20 AM
  3. Vgt calibration
    By 30 RUM in forum Cummins 6.7L
    Last Post: March 12th, 2013, 04:32 PM
  4. NON-VGT turbos
    By cumminsDK in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 12th, 2012, 04:29 PM
  5. deleting a tune
    By way2much_01 in forum Gen III V8 Specific
    Last Post: November 9th, 2007, 12:37 PM
