Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 31
Thread: 2016 Camaro E92 MAF Scale question.
  1. #21
    Member SPi's Avatar
    Jan 2010
    OK thanks joecar
  2. #22
    I'm told that GM put that jump in there... it's not possible to rescale the axis.
    It's possible. Just not with EFI Live GM did it the way they did to maximize the resolution of the actual operating range.
    EFI Tuning LLC
    www.efi-tuning.net
    tim@efi-tuning.net
    (888) 8EFI-TUNE
    (888) 833-4886
  3. #23
    Aug 2007
    So what is the latest on this? Can we not rescale with this software?
  4. #24
    Aug 2007
    So I will take it the silence means no?
  5. #25
    Member SPi's Avatar
    Jan 2010
    It can be rescaled, just not with EFI Live yet
  6. #26
    Quote Originally Posted by Wichita Dyno View Post
    The MAF axis is just a non-visible calibration in EFILive. I don't see any reason why it can't be made visible so it can be re-scaled by the tuner. I'll add it to the list of things for the next update.
    Meanwhile the way it currently determines the lookup values from the MAF table between 8550 and 15000 is via linear interpolation.
    For example assuming the last two entries in the table are:
    8550=360
    15000=1150
    then if the Hz value was 12000, then the value returned from the lookup table is computed by the ECM as follows:
    g/s = 360+v*(y/x) where
    v = 12000-8550
    y = 1150-360
    x = 15000-8550
    so the lookup value when Hz=12000 is calculated as: 360+(12000-8550)*(1150-360)/(15000-8550)
    360+3450*(790/6450) =
    360+3450*0.12248 =
    782g/s
    To help with tuning right now, here's what the values are for various points in between the last two cells:
    Code:
       Hz     g/s
     8550     360
     8600     366
     8650     372
     8700     378
     8750     384
     8800     391
     8850     397
     8900     403
     8950     409
     9000     415
     9050     421
     9100     427
     9150     433
     9200     440
     9250     446
     9300     452
     9350     458
     9400     464
     9450     470
     9500     476
     9550     482
     9600     489
     9650     495
     9700     501
     9750     507
     9800     513
     9850     519
     9900     525
     9950     531
    10000     538
    10050     544
    10100     550
    10150     556
    10200     562
    10250     568
    10300     574
    10350     580
    10400     587
    10450     593
    10500     599
    10550     605
    10600     611
    10650     617
    10700     623
    10750     629
    10800     636
    10850     642
    10900     648
    10950     654
    11000     660
    11050     666
    11100     672
    11150     678
    11200     685
    11250     691
    11300     697
    11350     703
    11400     709
    11450     715
    11500     721
    11550     727
    11600     734
    11650     740
    11700     746
    11750     752
    11800     758
    11850     764
    11900     770
    11950     776
    12000     783
    12050     789
    12100     795
    12150     801
    12200     807
    12250     813
    12300     819
    12350     825
    12400     832
    12450     838
    12500     844
    12550     850
    12600     856
    12650     862
    12700     868
    12750     874
    12800     881
    12850     887
    12900     893
    12950     899
    13000     905
    13050     911
    13100     917
    13150     923
    13200     930
    13250     936
    13300     942
    13350     948
    13400     954
    13450     960
    13500     966
    13550     972
    13600     979
    13650     985
    13700     991
    13750     997
    13800    1003
    13850    1009
    13900    1015
    13950    1021
    14000    1028
    14050    1034
    14100    1040
    14150    1046
    14200    1052
    14250    1058
    14300    1064
    14350    1070
    14400    1077
    14450    1083
    14500    1089
    14550    1095
    14600    1101
    14650    1107
    14700    1113
    14750    1119
    14800    1126
    14850    1132
    14900    1138
    14950    1144
    15000    1150
  7. #27
    Paul, thanks!
  8. #28
    Here's what the entire table (when extrapolated) would look like when plotted in Excel.
  9. #29
    They go linear above 8500Hz...?
  10. #30
    Yes. All data between cell values in all tables is interpreted using linear interpolation.
    https://en.wikipedia.org/wiki/Linear_interpolation
  1. ol maf tune or ve maf open loop and lambda question
    By 400ss in forum Gen III V8 Specific
    Last Post: February 1st, 2015, 07:12 AM
  2. VE table scale up by how much?
    By queso in forum General (Petrol, Gas, Ethanol)
    Last Post: October 8th, 2007, 12:23 PM
  3. LM-1 AFRs in Scan off the scale.
    By curtbriggs in forum General
    Last Post: December 24th, 2005, 06:25 AM
  4. I need a stock MAF for a 2000 LS1 camaro!
    Last Post: October 25th, 2005, 03:20 PM
