I have a 98 LS1 camaro that was originally a manual trans. I have taken out the M6 and installed a TH400 auto with a gear vendors overdrive. The car has 4.11 rear end gears and the overdrive is .75 ratio. There is just so many things that have changed i'm not sure what the best way about making the proper changes would be. I went in and changed the gear ratios for the trans and changed the gear ratio for the rear end and calculated everything related to tire size. If there is something I am overlooking please let me know I am pretty new at this and learning daily
