Results 1 to 3 of 3
Thread: LML speed limiter issue
    May 2008
    Default LML speed limiter issue
    On my 15 and some customers LML's I have tuned. If I stand on it it will go well up over 120 but if I let off it has no power still it get back below 75-80. I know this has something to do with the switches but have yet to come up with the right combo for this one issue yet. any help. I have the fuel tables set to 0 for the speed limiter also.
    2015 3500HD crew cab long bed, 6" fabtech, slightly tuned, emissions intact.
    2005 dmax ccsb, EFI live tuned DSP 5 Full built motor, S471 billet single, More better built trans this time. and lots of other things.
    1984 CJ7 powered by a 2000 LS1. 4L60E.
    2012 Jetta TDI 6 speed manual, (yes the dirty the bastard haha)
    2003 Jetta TDI,
    1986 K10 LQ4/4L80E
    Member jay p's Avatar
    Dec 2005
    I'm not sure if the 2500/3500s are the same, but on the 14 and newer 1500s the speed limiter is controlled by the BCM unless it's set to ECM in the ECM tune.
    Jay
    2019 Sierra 6.2l
    2017 2500HD L5P
    2010 2500HD LMM (sold)
    2005 Harley Ultra Classic
    Junior Member Sickll7crenshaw's Avatar
    Aug 2016
    Bumping this thread to see what others have figured out, the 15.5 im messing with is doing the same as Lee's but I can run this one up to 90 let off and it will not pick power back up unless I drop speed below 55mph, maybe a switch combo along with some changes in the speedo limiter parameters will do the trick? I see the 15.5s have misc parameters so maybe raising those numbers along with the PTO, Can Bus speed limits hopefully fixes the issue, if anyone could chime in i would sure appreciate it! Thanks
  1. LML Speed Limiter changes not working
    By madmanmartin in forum Duramax 2011+ LML / LGH
    Last Post: June 30th, 2016, 05:27 AM
  2. LB7 Speed Limiter/ High speed defuel???
    By larski156 in forum Duramax LB7
    Last Post: April 28th, 2016, 11:11 AM
  3. LML Speed Limiter Removal
    By robo121 in forum Duramax 2011+ LML / LGH
    Last Post: June 19th, 2014, 02:31 PM
  4. Replies: 21
    Last Post: July 7th, 2013, 11:31 AM
  5. LS3 speed limiter issue
    By GPI_Will in forum E37, E38 & E67 PFI ECM's
    Last Post: September 29th, 2012, 09:11 PM
