I'm into my 18th logging session now. My VE table just doesn't want to settle down. There are some pretty wild swings in it... Does anyone have some pointers?
The log I am posting was taken after flashing the tune file that is attached.
Besides the unruly VE table, it seems to be running very good. Much smoother than it ever has prior to adding the E-force SC, new injectors, etc, as shown by how nice the ve looks in those lower throttle cruising and idle areas... I am getting some occasional lean tip-in which is noticeable by a slight stumble or hesitation. Is the lean tip-in what I am seeing in the VE logs?
Do I need to decrease the PE TP% lower than 25%?
Over 4000 RPM or so it starts going rich, pulling timing, and it literally falls flat on it's face, but that's mainly because I haven't spent much time working on those areas yet.
I'd really like to get the VE more stable, as I've just been bouncing back and forth in a lot of the wild cells and not really seeing a change in the logs.
TUNE: Boost-Base_016.ctz RESULT LOG: LS1B_0126.efi
Data filter used:
Crappy VE table. I haven't spent much time in the higher RPM range yet:
