Results 1 to 10 of 15
Thread: newbie tune
    Aug 2016
    Default newbie tune
    Can someone look over this tune and tell me what u think. any help would be appriciated!! seems like tables may be fighting themselfs??
    specs
    gen 3 5.3
    317 heads
    80lbs FIC injectors
    walbro 400 fuel pump with vette fuel filter (internal reg) returnless
    th400 trans
    76mm turbo intercooled
    SD tune with 3bar duramax MAP
    running about 15psi boost
    if u need more info let me know
    startingtune.ctz
    What is measured rail pressure (measure with FPR reference hose temporarily removed)...?
    What vehicle is this in...?
    Aug 2016
    58psi rail psi. Pressure reg is inside fuel filter. It's in a s10.
    So your FPR is un-referenced (i.e. no hose going to intake manifold)...?
    I'm working thru your tune...
    VE tables are not right.
    Aug 2008
    Im going to assume he has the same setup as I do and correct there is no hose going to manifold. Its a setup out of an 01ish vette.
    Sent from my SAMSUNG-SM-N910A using Tapatalk
    Aug 2016
    Sparkinac is correct
    Aug 2016
    Please need help !!!!
    Ok, IFR looks right.
    But both VE tables look wrong....
    Aug 2016
    Any suggestions to fix them?
  1. Help a newbie with tune after Cam upgrade
    By noesfacil in forum Conversions / Aftermarket Parts
    Last Post: August 18th, 2021, 03:29 AM
  2. Newbie Question: LQ4 Silverado Tune from AT --> MT <?>
    By redXman in forum Gen III V8 Specific
    Last Post: October 24th, 2014, 01:57 AM
  3. Newbie looking for advise with first tune
    By Dieselman in forum Gen IV V8 Specific
    Last Post: October 3rd, 2011, 01:09 AM
  4. First tune record - help a newbie
    By 68problemchild in forum Conversions / Aftermarket Parts
    Last Post: September 25th, 2010, 02:37 AM
  5. Newbie Supercharger tune questions........
    By FreddyG in forum Gen III V8 Specific
    Last Post: June 19th, 2007, 04:11 PM
