Results 1 to 2 of 2
Thread: LB7 ECM repair, AB28F400B5
    Lifetime Member DURAtotheMAX's Avatar
    Nov 2005
    Default LB7 ECM repair, AB28F400B5
    Quick question about LB7 ECM repair.
    I have a couple dead ECM's here. I have a Willem GQ-4x4 programmer, and a PSOP-44 adapter obviously.
    I have a bunch of LB7 .bin files. I assume I can just flash those straight with the Willem? Or do I have to click byte-swap?? Are there any other special settings that have to be ticked in the Willem program?
    In the Willem program, they have AB28F400BX-B, and AB28F400BX-T....The LB7 flash chip says AB28F400B5. I THINK you have to select BX-B....not BX-T. Doesnt the BX-T have a different pinout on the chip?
    The other question I have is regarding replacement flash chips. Finding the Intel AB28F400B5 is almost impossible, except from some random Alibaba/Aliexpress sources. Id rather not wait a month for chips that may or may not work.
    I found a page or two that says on some LS1 PCM's, you can substitute an AMD AM29F400B chip (which is a little easier to find)...does anyone know anything about this? Would it work on an LB7?
    Ben
    2005 Silverado, CC/SB, 4x4, LT, LILLY/Allison
    12.9s @ 108 mph
    many thanks to Ross and Paul
    You can't use the AMD Chips, the erase-flash process is different therefore the ECM will never be able to do things like a VIN change because it won't know how to handle the AMD chip.
    I don't know the subtle differences between the Intel chips but I don't see why you would need new ones anyway. Remove the Flash, clean it up, erase/flash a good file then refit.
    You don't want byte swap set or anything like that.
  1. Bricked LB7 ecm
    By catman3126 in forum Duramax LB7
    Last Post: August 10th, 2015, 06:00 AM
  2. Have I bricked my LB7 ECM?
    By WarEagle1 in forum Duramax LB7
    Last Post: March 2nd, 2014, 01:43 AM
  3. Lb7 eprom ab28f400b5
    By DmaxTraxx in forum Duramax LB7
    Last Post: December 8th, 2013, 02:43 PM
  4. Anybody got an LB7 ECM for sale
    By cappyd892 in forum Duramax LB7
    Last Post: February 23rd, 2012, 02:28 AM
  5. Intel Flash ab28f400b5-b80
    By dave.au in forum General (Petrol, Gas, Ethanol)
    Last Post: May 27th, 2008, 05:45 PM
