I used the corvette style fuel filter with built in regulator that has the return built into it. I have been reading the info on here but if I understand it right as I have ls3 injectors at 58psi, pretty much means no matter what the injectors are putting out 42lb/hr fuel. So would I be better loading that OS onto my 411 pcm or can i continue using the stock 0S from 02 denali (but with ls3 data)?
Sent from my SAMSUNG-SM-N910A using Tapatalk
