Results 1 to 10 of 13
Thread: loosing throttle 6.0 boosted, cos 03150003
    Jan 2011
    Default losing throttle 6.0 boosted, cos 03150003
    Hello,
    I have a 2006 6.0 in a 69 c10, the pcm is flashed to a 2003 now with cos 03150003. and matching pedal and tac module
    The truck runs fine, still a little rich but that will be changed.
    As soon as i go over about 60% throttle, a maf code gets set, truck goes to an idle and i lose control over the throttle.
    Once i delete the code, the throttle works again.
    Im not running a MAF or o2 sensors, so open loop.
    I have the proper map sensor etc.
    Please have a look at the attached tune, i must have missed something.
    Thanks in advance69 V3.ctz
    Post some log files.
    If you are running without MAF, you should have an immediate MAF DTC (this is then causes PCM to use VE only).
    It sounds like the MAF and MAP (and possibly the ETC) sanity tables (in Engine Diagnostics) need to be adjusted.
    Jan 2011
    Yes there is a maf code. I run just the iat. I just blew the transmission so I'll have to wait till tomorrow or later tonight to post a log file. I'll have a look in those tables. Thx so far
    Jan 2011
    Default log file
    LS1B_0083.efi
    please have a look at the short log file. it was under acceleration and throttle died
    Jan 2011
    i am going to try a different pcm
    Try this: set C5501 to 500.
    Jan 2011
    made no difference
    Jan 2011
    could it be B6612?
    Quote Originally Posted by derkscustomcars View Post
    could it be B6612?
    You could try editing that...
    but if you think TC is kicking in, then disable TC.
    Jan 2011
    i did, i have to ad that i am using a turbo 350 transmission. the pedal and tac module are the right ones for that pcm. i have switched out the tac module with a known good one.
    still no go
  1. Loosing 4th once converter is locked
    By alian in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 6th, 2011, 10:15 AM
  2. loosing sleep over my 1998 454 -compcams timing issue
    By camminchevy in forum Vortec V6/V8 Specific
    Last Post: April 29th, 2011, 07:01 AM
  3. Missfire, loosing spark irregularly
    By Ram Air IV in forum Gen III V8 Specific
    Last Post: May 20th, 2009, 12:01 AM
  4. Wide Band Loosing Calibration
    By sdhager in forum General (Petrol, Gas, Ethanol)
    Last Post: September 23rd, 2008, 12:30 AM
  5. Loosing 18* of timing at WOT!
    By johnsZ06 in forum Gen III V8 Specific
    Last Post: June 2nd, 2007, 08:39 AM
