7 mod code.ctz
i guys
what wrong with my delete tune truck go in limp mode after couple miles all sensor are unplug on dpf
thanks for your help
7 mod code.ctz
i guys
You need to get rid of any dtc that are setting
excuse me my English are not good
I need to set off other code ?
There is some codes that need to be turned off in your tune. Run a code scan and see what codes the ecm is setting.
I hav
You need to turn off all your dpf and egr dtc enablers
if someone can modify my tune I will pay for it tanks
give this one a try
2008 Chevrolet 3500HD DRW LTZ
285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
Sold - 2004 LB7 Duramax, EFI Live with DSP5 Tune
stage 4 SC transmission, 265/70/16 tires
Ok tanks i will try
Any update? Did it work?
