Guys,
I'm having some issues plugging in injector data into a tune file. Quick rundown....We have a 2003 Silverado 2500 with a LQ4/4L80E setup. The engine is now 408 cu. in., LS3 heads, L92 escalade intake, LS3 injectors and a 87mm "truck" throttle body running a X-Link throttle body harness adapter. I have converted and plugged in all the LS3 injector data into the LS1B ECM. (12579405 OS) After I save the file and reopen it several calibrations change on their own...B4003, B4004, B4005, B4006, and even B4001 mysteriously change. If you give this truck any sudden throttle it will go dead lean and start popping bad out of the exhaust due to it being so lean. But I know I've got to get this file straightened out first before I start doing any kind of tuning/adjustments. Has anyone ever seen their injector data change when saving their file? Mainly B4005 (Small Pulse adjust) shows crazy numbers after you re-open the tune file. I've attached the tune showing the "changed" data. The data that is supposed to be in there is LS3 injector data. If you look at the file you can see it's nowhere close. Can anyone shed any light on this one?
