Results 1 to 10 of 17
Thread: im lost with the no throttle
    Jan 2011
    Default im lost with the no throttle
    Hello,
    Does anyone have a running os 03150003?
    i would like to try a known good tune. not to worried about afr etc.
    thanks
    Also, did you try to disable traction control...?
    Jan 2011
    yes i did, no go at all. its drive-able but i cant stomp on it.
    I've seen this on the E39 when hitting 7200 rpm with WOT... all I could do was reduce the rev limiter to 7000 rpm, the lack of tables made it very frustrating.
    The 411 has more sanity tables, may have to try each one.
    Are you seeing any DTC's...?
    Dec 2014
    C6102 needs to be adjusted. C6101 will do the same on decel with boost or engine lug with boost.
    Try maxing them to see if the issue goes away.
    Jan 2011
    i already maxed them out. a little better
    Dec 2014
    Is it still killing the pedal?
    Jan 2011
    Yes. I have to erase codes and it comes back. It seems to happen when the maps hits 154kpa
    Dec 2014
    Whats the codes?
    Jan 2011
    the only code i get is a maf code because i dont have it. and its set up as per custom os instructions. could it be the boost moving the throttle blade and shutting it down?
  1. Runaway throttle and throttle sticking, what tables can affect this?
    By RD in SD in forum E37, E38 & E67 PFI ECM's
    Last Post: May 11th, 2013, 02:20 PM
  2. Trans hits 4th hard with light/no throttle, fine with moderate throttle
    By Supercharged111 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 4th, 2013, 12:10 PM
  3. Lost. LS1 throttle translation table
    By Eric Schieb in forum Petrol / Gas
    Last Post: August 12th, 2011, 12:33 PM
  4. E38 - Throttle Cut / Throttle Blip
    By Z06-GT3 in forum Lounge
    Last Post: June 14th, 2011, 04:16 AM
  5. how to tune throttle follower and throttle cracker?
    By z28ls1818 in forum Gen III V8 Specific
    Last Post: September 19th, 2010, 03:43 PM
