Results 1 to 9 of 9
Thread: E38 VVE Calculated Airflow
    Mar 2009
    Default E38 VVE Calculated Airflow
    Does anyone have a calculated PID to calculate VVE airflow (g/sec) for an E38? I noticed the PID in the BBX PIDs, but don't see it in EFI Scan V7.5. I'd like to compare MAF airflow against VVE calculated airflow.
    EFI_V8PIDS
    ECM.MAFSD
    Thanks in advance!
    I have a bunch of calc pids, let me look thru them.
    I haven't forgotten, I've just been overly busy...
    Mar 2009
    Great thanks Joe!
    Have a look at this calc_pids.txt (attached)...
    CALC.VEN calculates VE in g*K/kPa from MAF [g/s].
    CALC.MAFN calculates MAF in g/s from VE (via VVE mapped to VE [g*K/kPa]).
    Try it out and let me know (post logs) so we can fix it if necessary.
    ( possibly we may have to edit it to suit your wideband )
    ** you have to rename the file to "calc_pids.txt"
    Mar 2009
    Thanks Joe!
    I went through the Calc_PID test file and tried to make sense of it. lol
    I attempted to change the BEN factor from Lambda to AFR since that it was the NGK wideband outputs, unless I use another Calc PID to go from AFR to Lambda. Thought it would just be another step. Does it look right?
    Can a SELBEN be created to use LTFT with AFR is equal to 14.68?
    Is there anyway to calculate VVE values or coefficients like CALC VET does on the Ls1B PCMs?
    Maybe I should just get some logging done! Haha
    Looks correct
    ( can you see that CALC.WO2BEN and CALC_BEN_NGK1_E38 are now identical )
    I'll add a SELBEN pid shortly.
    Yes, please take some logs.
    Mar 2009
    Awesome, thanks!!
  1. Please help me tweak my E38 VVE.
    By Jayrcr3 in forum E37, E38 & E67 PFI ECM's
    Last Post: November 30th, 2011, 07:40 PM
  2. Need E38 VVE tuning help
    By 2007chevy5.3l in forum E37, E38 & E67 PFI ECM's
    Last Post: November 26th, 2011, 08:34 PM
  3. E38 afm vve
    By VEGASROBBI in forum E37, E38 & E67 PFI ECM's
    Last Post: March 1st, 2010, 06:40 PM
  4. E38 VVE problems
    By johnv in forum E37, E38 & E67 PFI ECM's
    Last Post: April 26th, 2008, 12:09 PM
  5. Question about calculated airflow vs. measured airflow
    By JR_VETTE in forum General (Petrol, Gas, Ethanol)
    Last Post: October 1st, 2006, 05:37 PM
