Results 1 to 2 of 2
Thread: 411 & L35 on boat (problem)
    Aug 2016
    Unhappy 411 & L35 on boat (problem)
    Friends, Hello!
    Sorry for my English - I am from Russia
    I put the engine 4.3 (L35 from Blazer) and RMB 411 on boat
    I'm hooked
    - Starter (without a PCM, directly battery)
    - alternator
    - Crankshaft sensor
    - Timer (distributor)
    - MAP
    - EGR
    - Throttle
    - Coolant temperature sensor
    - Connector on the spider (injector). injector 6 pcs.
    Engine tries to start
    Filed the first two pulses to the injector. Then there is the pulse.
    This is very similar to the anti-theft system (immobilizer).
    Say to PCM 411 is anti-thief system (Pass Key, which powered by BSC).
    Or the engine does not start due to other reasons?
    Engine and PCM taken from two different cars
    These PCM
    serv.no. 12200411 DFNN
    *86DFNN910279FQQV* 12201281
    HDW NO.09386530
    Thank you!!
    Hi, have you disabled VATS and the other security items in the tune? If you have not, it will not run.
  1. problem loading new os 411 swap
    By haulinit in forum FlashScan V1
    Last Post: April 20th, 2009, 09:33 AM
  2. reading Problem ( LC-1 logwork & gage & EFIlive )
    By Ls1_Rulz in forum FlashScan V2
    Last Post: October 17th, 2008, 06:42 AM
  3. Come for a boat ride :)
    By ringram in forum Lounge
    Last Post: July 22nd, 2007, 05:37 AM
  4. Replies: 1
    Last Post: November 7th, 2005, 11:11 PM
Tags for this Thread
